OK stinger
Discussion in '2.3L (N/A & Turbo)' started by manny, Jan 9, 2006.
  1. manny Founding Member
    Dec 6, 2001
    Message Count:
    602
    TAMPA FL
    ok stinger i've been reading and reading all about the svo's and the turboing of the fox body mustangs and also been reading your entire web site and you have convinced me to build up a turbo charged 2.3 fox mustang.i will be selling my mustangII which has a very nice 302 in her that really runs good. if i could build a nice 2.3 turbo fox that would even run close to the II i would be really happy. just to prove the point i just bought a turbo 2.3 turbo motor from ebay for $41.00 dollars, i'm also watching a 1993 2.3 liter LX mustang. both are close to my home so i guess the quest to build a mild looking killer turbo'ed fox mustang begins:nice: . looks like i'll be reading your site that much closer. thanks in advance for all of the questions that might pop up:D
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Good to see I've made another "conversion" ;) I'm sure it will be fun.
    Let me know if you have any questions that aren't covered on my site...
  3. lit_mike_2001 New Member
    Jan 26, 2003
    Message Count:
    165
    Ada, OK
    for goodness sake, keep the 302 powered car put the same amount of money as you put in your 2.3 powered one, and in the end tell me which ones faster.
  4. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Oh man...here we go again ;)
  5. 88stangmangt New Member
    Nov 25, 2003
    Message Count:
    2,347
    Stafford,VA
    wait till im done with my 2.3.......302 production blocks are weak...if u want something to take boost and abuse a 2.3 is where it is at....watch what im saying when you take it apart. turboford also has tons of info and stinger has just about all of the stuff you need to build a 2.3 worth a d@mn. just remeber if you cut corners and be cheap things wont work out....
  6. mr_woodster Active Member
    Jul 28, 2003
    Message Count:
    1,316
    36
    Riverside, CA
    41$ ? Jenious, i bet he could fill his tank with that :ban:
  7. towbar New Member
    Dec 19, 2004
    Message Count:
    18
    Akron, OH
    I think you'll like the 2.3t a lot better. I finished my swap last year and I love to drive my 2.3 more than my 5.0.
    :flag:
  8. manny Founding Member
    Dec 6, 2001
    Message Count:
    602
    TAMPA FL
    needless to say that the motor will need to be rebuilt but it does come with the turbo,exhaust manifold and the complete long block. it even has the bell houseing and clutch assy.the type of the intake it has is the 4 in a row type.do you think this would work,put the turbo pistons in a 91-93 car, add the turbo and intercooler.would this work?
  9. manny Founding Member
    Dec 6, 2001
    Message Count:
    602
    TAMPA FL
    ok now,got the motor home and its sitting on the stand. looks like the motor came out of a 1984 ford turbo mustang. it has only one tube that goes to the actuater(witch is missing). turbo turns freely so does motor. i plan on rebuilding it from top to bottom before i install it into the car.stinger my question is should i get the ecu and harness from a TC in order to do the swap into a 87-90 mustang? i was reading your site and you used a TC motor to begin with and mine looks just a little different. thanks in advance:nice:
  10. 88stangmangt New Member
    Nov 25, 2003
    Message Count:
    2,347
    Stafford,VA
    that is what was used for mine...a t/c wire harness and a computer from a auto T/C becuase it has more aggressive timing tables.
  11. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    You'll want to get an 87-88 turbo coupe ecu. You'll also want a large air meter and 35lb injectors (which an 84 Mustang motor won't have).
    You'll also need about 12" of air meter wires/plug.
Share This Page
