ordering clutch, gotta question
Discussion in 'SN95 4.6L Mustang' started by 02nightmaregt, Oct 27, 2009.
  1. 02nightmaregt To hell with your Mustang, I want to see your HOG!
    Jul 1, 2007
    Message Count:
    638
    Ok like it says, I am ordering a new clutch, TOB, and Pilot bearing. I had my tranny rebuilt about a year and a half ago and when I did that I had ordered a Centerforce DFX w/ TOB. Well when my mechanic was putting everything back together we realized that summit had sent the wrong clutch. Anyways I ended up having to send it back and get a crappy clutch from a local clutch manufacturer. Well I also sent back the TOB and I don't think my mechanice even replaced that when he put it all together, so now its whining and making all kinds of horrible noise. Well I am now in the process of tearing the car apart and doing a little work to it (thank god for the dd:banana:) My question is, I am looking at a DFX and want to make sure I order the correct one this time. Here is what I'm looking at
    Centerforce DF800075 - Centerforce Dual Friction Clutches - Overview - SummitRacing.com
    I don't wanna go through ordering it and finding out its the wrong one again.
  2. joshjwc9 Member
    Jun 13, 2006
    Message Count:
    880
    18
    If you have the stock 3650 that clutch will fit.
    The things to look for is definitely the 1 1/6 shaft/11 diameter disc and the 10 splines.
    I would also order MM's FW adjuster and quadrant but use your stock cable! If I had to do it again, I would go Fiore or MM from the start!
  3. twogts4us Advanced Member
    Apr 2, 2004
    Message Count:
    4,084
    68
    Have you called Summit? They have great customer service.
  4. 02nightmaregt To hell with your Mustang, I want to see your HOG!
    Jul 1, 2007
    Message Count:
    638
    Ok so this is what I need for the turdy650, I mean 3650? Good to know, thanks. Also I plan on doing the clutch/TOB/PB, new stock FW, Quadrant, firewall adjuster, and new stock cable. Where can I snag the Fiore? I want to get it right this time, since I can actually do it myself and take my time.
    Twogts4us: yes I called them and the guy I talked to arued with me saying that they sent me the right one. I didn't want to argue with him so I just asked if I could send it back and get my money back. I have always liked summit so I'm not really that mad with them, I mean people make mistakes. I'll just make sure when I order this time I specify what application it is needed for.:nice:
  5. 02nightmaregt To hell with your Mustang, I want to see your HOG!
    Jul 1, 2007
    Message Count:
    638
    Ok so I am about to order the clutch I linked, now I need ot order the TOB and PB. Should I stick with FoMoCo parts or is the Centerforce TOB any better?
  6. joshjwc9 Member
    Jun 13, 2006
    Message Count:
    880
    18
    You can go with the Ford stuff, but you should wait to see if some other Centerforce users input. All I know is that the RAM stuff that came with my Powergrip is working perfectly!
  7. bakos24 I find there is nothing better than a tasty wiener
    Mar 31, 2005
    Message Count:
    2,721
    39
    68
    I have that same clutch. Awesome clutch it is. I used a Ford TOB with mine. I knew the they were one of the best TOB so I didn't want to have to try a Centerforce one and end up having to redo it. Not saying that the Centerforce TOB are bad, I just didn't want to chance it :shrug:
  8. 02nightmaregt To hell with your Mustang, I want to see your HOG!
    Jul 1, 2007
    Message Count:
    638
    Cool, I'll just go ahead and order the Ford party then. Samn for the Piolot bearing I assume?
  9. GDTrumbo Member
    Jan 22, 2009
    Message Count:
    208
    Her's a good write-up on quads & adjusters:
    http://www.slantnosefox.com/techarti...djustment.html
    And here is a link to Lethal Performance:
    Fiore 96-04 Micro-Click Firewall Adj. & Clutch Quadrant Kit [FIORE-ADJKIT] : Lethal Performance, Performance parts for Ford Mustangs
    GT
  10. 02nightmaregt To hell with your Mustang, I want to see your HOG!
    Jul 1, 2007
    Message Count:
    638
    Awesome dude! Thanks a lot for the links. Bit pricey but I'm thinking its worth it to buy once:nice:
  11. oxfordgt New Member
    Apr 30, 2006
    Message Count:
    279
    Always remember to order a clutch that has a lower torque rating then your transmission. A clutch is much cheaper then a tranny. I am running a spec stage 1 with my stock tranny and making 700rwhp/573rwtq with no problems and no slipping.
Share This Page
