Overheat/Ignition Problem?
Discussion in '94-95 Tech' started by onebadsixxx, Jul 13, 2009.
  1. onebadsixxx New Member
    Jul 13, 2009
    Message Count:
    21
    Hey everyone, not so much a newbie to the mustang world, but a newbie fo sho to stangnet. Ill introduce myself later on as time goes by, though I need to make my first post here, cuz the 5.0 I bought few months back is really starting to **** me off.
    First off, its a 1995, coupe, 190,000 miles. Whats been done to it to help out in the troubleshooting to follow? That I can remember its got a NEW: fuel pump and filter, transmission, pullies, a/c compressor, bbk cold air intake, spark plugs, cables, rear main seal, msd coil, msd dizzy cap [still a stock dizzy], brakes and suspension. All the new things have been on the car for about 2,000 miles.
    Next, I live in Las Vegas. Currently the temps have been always over 100 degrees.
    Ok, so the car after being driven for about an hour or so, seems to overheat, itll bog like a SOB, and die. The gauge in the dash still reads normal, though the engine its WAY hot to touch after being driven. Dont think it should be THAT hot, even the hood latch is too hot to grab. Anywho, I try to turn the car back on and itll turn on for a second, then itll die. I would have to wait about 2 to 3 hours, and itll crank right back up as advertised and itll run fine.
    I took it in once, when the problem first started and thought it may have been the fuel filter. It got changed. And the problem kept coming. That was about a month ago. I took it in again this past saturday to another shop who can read codes through a OBD1 diagnostic code reader and they found NOTHING. Meaning, everythings been working as advertised ever since the problem started.
    Confusing!
    Now things that have been discussed with other people [with local friends, friends off forums] that the problem may be would be:
    1. Clogged Cat
    2. Bad Ignition Control Module
    3. Dirty MAF/TPS/IAC
    4. Bad PIP
    5. Bad Distributor altogether
    What I personally think now after finding out the car never threw a code, that this is being done by some natural cause of physics. Now that I know I have all power and I have all fuel system components working to get the engine on [still with 45 psi to the injectors], whats left to check is spark. So maybe some electrical connection somewhere in the ignition system is getting too hot, itll expand the "electrodes" in the QD's enough to disconnect themselves, then after letting it sit for a while, itll cool down, reconnect, and voila. Car works.
    Wait, theres more...
    Then this happened this afternoon, my LOW OIL light came on. Why? I dunno, cuz I know I dont have a leak cuz I dont leave any puddles. I may be burning the oil or the leak may just be spreading the oil thats leaking out all over the undercarriage while I drive. So with low oil, could unlubricated friction in the internal's rotation cause the engine to over heat, thus causing the electrical problem if there is one?
    Im pretty sick of whats going on, and I need some real answers, cuz everyone else is just as stumped as I am.
    Thanks guys!
    -John
  2. earleys94gt Member
    Aug 31, 2003
    Message Count:
    824
    Welcome to StangNet!
    Just because you have no puddles does not mean you are not leaking oil. Chances are, with that kind of mileage, your engine is burning oil and it is coming out the exhaust. While the car is idling look for smoke from the exhaust, blue colored, from the tail pipes. You could probably smell it too.
    As for the cooling system, the factory Ford system isn't the world's best. Since you live in Vegas, I would atleast look into getting a 160* thermostat, Fluidyne or equivelent radiator, and a high flow water pump. You could also look into getting a chip or other programmer to turn on the fan at lower temps.
    If one of the cats was clogged, you would probably have a condition where the engine would not rev past a certain RPM. That was what happened to me when my cat got clogged.
    It probably would not be a bad idea, in general, to clean the MAF and such. It may not be the source of the problem, but is a smart idea to do.
    The dizzy on our cars are known to some problem cases. With the amount of times yours has been used over the course of those 190,000 miles I would venture to say it is somehwat worn out.
    I would advise you to do some test on your car, leak down, compression etc. and maybe check the voltage at some of the major ignition componets to determine where the problem might lie.
  3. TBCOBRA88 New Member
    Jul 12, 2009
    Message Count:
    26
    The running and cutting off issue could be the pickup in the distributor. That was my case. Run for a while then die. and not crank up till hour or two later. It's a cheap part, but a PITA to change, as it requires some pressing gears off and back on.
  4. earleys94gt Member
    Aug 31, 2003
    Message Count:
    824
    If that is the part that is bad, get a quality one from somewhere like Napa or Ford. Don't get some cheap Auto Zone one.
  5. onebadsixxx New Member
    Jul 13, 2009
    Message Count:
    21
    Update to an old thread, but figured I update on what the problem was. Bad ignition module. Since the change, its been money. Thank God...
Share This Page
