painting engine compartment
Discussion in 'Mustang Sound & Shine All' started by jaidedeye, Aug 2, 2004.
  1. jaidedeye New Member
    Apr 5, 2004
    Message Count:
    633
    Goldsboro nc
    i have a 90 fox and i was wondering what is involved in painting the engine compartment without ripping everything out??
  2. stang22 Active Member
    Jan 29, 2003
    Message Count:
    1,316
    36
    Destin, Fl.
    Either way, it is going to be a lot of work. Overspray would be a nightmare, but it can be done. The main thing would be to get all of the wires out of the way. You definately have your work cut out for you if you want to do it the right way.
    Tim
  3. 85GTlover New Member
    Mar 21, 2004
    Message Count:
    725
    USE A SPONGE!!!!!!!!......Clean it real,real good. Get a good foam sponge cut it into small squares.....put your mind back to preschool.......just use small amounts.....no overspray..no mess.......don't try to cover it all at once just cover it, then let it dry some then do it again, then if you want real nice again. Spraying is a waste of energy and time masking things. Make sure you clean it all well first, that is what counts, scuff it a bit and wipe it real good....tack cloths are best or microfibre towels.
Share This Page
