ported heads
Discussion in '94-04 V6 Mustang' started by mustangmtc85, May 15, 2006.
  1. mustangmtc85 New Member
    Apr 26, 2006
    Message Count:
    28
    im interested in porting my heads on my v6. does anyone know how much this would cost me. how much horsepower gains do you get out of this?, also after this process is done , will it deepem the tone coming from my true duel flowmaster 40 series? , if so how much deeper(sounds kind of raspy right now)
  2. Skymarshal Member
    Nov 5, 2004
    Message Count:
    569
    www.supersixmotorsports.com claims a 75 HP gain from installing their ported heads, but that includes a more aggressive cam. You probably wouldn't do as well if you just installed ported heads- maybe 20-30 HP.
    It won't change the deepness of your exhaust system. If you're looking for a deeper exhaust tone, trying different mufflers or getting a GT are your options. If you spend a lot of time trying to get a deep exhaust tone by using larger exhaust pipes or whatever, you'll probably wind up hurting your HP or torque. Only a GT will make both, and that's just how it is.
  3. 97sally6 New Member
    Nov 15, 2005
    Message Count:
    134
    i thought a more aggressive cam would make a throatier tone, at least at idle. you woulod think a beefed up engine would be deeper, no matter if it wa a 6 or 8
  4. mustangmtc85 New Member
    Apr 26, 2006
    Message Count:
    28
    i thaught that was true too:shrug: to atleast make a significant improvement in sound. do you guys know if magnaflow mufflers sound better on v6's than flowmaster
  5. RaceDvr50 New Member
    Jul 26, 2005
    Message Count:
    128
    The biggest change you can make in your exhaust tone is to remove the cats.
  6. 97sally6 New Member
    Nov 15, 2005
    Message Count:
    134
    LT headers will deepen the tone, so will bigger pipes if you dont already have 2.5", ive heard that removing the cats will add to the raspiness on a 6, as for the magnaflow mufflers, ive got them on my car and love the sound. its noticeably different than flowmaster and doesnt sound like every other mustang on the street
  7. mustangmtc85 New Member
    Apr 26, 2006
    Message Count:
    28
    if i go with 2.5" will i loose performance thanks to back pressure? what kind of magnaflow mufflers do you have? what do you mean by it doesnt sound like every other mustang on the street, are they deep sounding (more deep than flowmaster)? tell me your set up. I have true duels with no midpipe so its duel cats, how would this set up sound with magnaflows becasue i heard magnaflow systems are usually set up for single converter systems which split after the converter. My new threat debates flowmaster vs magnaflow so you can submit your reply there if you want:SNSign:
  8. 97sally6 New Member
    Nov 15, 2005
    Message Count:
    134
    ive heard people say that you will, and some people say you wont.. i know 2.5" gives you a better tone, as for power loss, i really dont know. i know theres somebody on here who has the LT headers and offroad x-pipe, and im pretty sure its 2.5". i have stock headers, stock cats, and a custom x-pipe with 2.25" pipes going into magnaflow mufflers and 2.25" pipes out the back. the mufflers are the satin stainless with 2.25" inlet/outlet, but im not sure of the exact size of the muffler. the sound is deep at idle and low rpms, then as they go up, the sound isnt so deep as it is more race sounding instead of just being loud.
  9. mustangmtc85 New Member
    Apr 26, 2006
    Message Count:
    28
    does anyone have a cost estimate for me to port the heads :nonono:
  10. mustangmtc85 New Member
    Apr 26, 2006
    Message Count:
    28
    is there any other way to increase compression
  11. RaceDvr50 New Member
    Jul 26, 2005
    Message Count:
    128
    To increase compression there are really only two choices neither of which you will like. You can switch out your pistons or you can change your heads to something with a smaller cc. You could shave your heads a little bit and get a little but it wouldn't be real significant. Unless someone knows of a hot head for the six I think pistons would be way I would go of course that's not really a bolt-on.
  12. Roland69 Sergeant Tangnet
    Sep 17, 2005
    Message Count:
    3,102
    I heard the heads and upper intake and maby cam off a windstar van were a good mod for the stang (the older 3.8 in the pre 96 or whatever year they switched)
    I cant remember where I read this. But I remember seeing a green fox notch in a MM&FF mag not quite a year ago with a 3.8 that would smoke most V8's (I think it was the six offender) and they said the plastic split port induction intake was one of the best flowing intakes for the 3.8
  13. TMX New Member
    May 24, 2005
    Message Count:
    225
    That was Super Six Motorsports 4.3L Stroker using the windstar plastic intake (which is also the same as the F150's intake, but the F150 is metal and stronger), plus they threw a shot of nitrous in it to run 10's.
    The sound will change some with a cam. A deep sound is caused by the frequency of the wave. An I4 has a high pitch because it has 4 cylinders firing out of the same header causing a short frequency, V8s have 4 cylinders in one header, but those 4 don't fire off back to back thus increasing the length between the peaks of each pressure wave. A cam can imitate this by changing the timing of the exhaust valve thus spacing out the peaks alittle more, decreasing the frequency and creating a lower pitch. But a V6 sounds like it does because the 3 cylinders fire off closer and more often than the 4 of a V8.
  14. GREENBIOCH Founding Member
    Mar 23, 2002
    Message Count:
    1,247
    another place for people thinking of camming or porting and engine internal stuff to check out is here..... http://rpm-mustangs.com/cart/home.php
    I also have a cam from them that i never did install, but i don't have my 6 anymore.
Share This Page
