Possible audio/engine problem
Discussion in '94-95 Tech' started by Chronos[AsG], Jan 1, 2004.
  1. Chronos[AsG] New Member
    Dec 20, 2003
    Message Count:
    84
    NC
    Frist, let me quote another post I made in Sound & Shine:
    I have noticed two things since I posted this: First, 99% of the time it begins to hum when I press on the brake. Second, it does not matter if the car/engine is hot or cold.
    Early this morning I was leaving a friend's house and I started the car to let it warm up. As it idled (in Park) I noticed a high pitched whirr. This is nothing new, I believe I have heard this before. But I noticed that if I pressed on the brake the whirr dropped in pitch.
    This caused me to wonder if this whirr was my alternator, and if I possibly have a bad alternator and this is what is causing this problem with my stereo system. I believe the alternator is the stock unit that came with the car in 1994. So does anyone know if this is what could be causing my problem?
    Some other minor points:
    Since that first quoted post I have grounded all my stereo components to the same piece of metal in the dash. One ground is a few inches away from the others but I dont think it would be enough to cause a ground loop.
    Second, I have ordered a new (well, used) front amp off of eBay in case that's what is causing the problem. The two rear amps were replaced last year.
    There are only two other things which I can think of that could be causing the radio noise, though I dont know how likely either are.
    First, I have noticed that the AM/FM antenna wire runs pretty close to the stereo grounds and the amplifier near the head unit.
    Second, I have different brands of brake pads on the front and rear brakes. The front are stock and the rear are some aftermarket brand. I don't see how this could be affecting anything but I think I have read something about the car being grounded through the brakes and tires.
    If anyone has ANY idea what I can do to fix this please let me know. This thing is driving me crazy! :bang:
  2. cjones Founding Member
    Jul 20, 2002
    Message Count:
    1,557
    36
    Avondale, AZ
    since it does it when the engine is also cold. remove the belt and run the engine at idle. if it does it then the alt is not at fault.
    ford had a TSB (TSB 01-7-3)for radio whine/buzzing from the fuel pump.
  3. Ethereal Zer0 Founding Member
    Sep 27, 2002
    Message Count:
    1,885
    38
    Everett, WA
    Any idea if the whine/buzzing stops if you replace the fuel pump?
  4. Gone2 New Member
    Feb 19, 2004
    Message Count:
    33
    I've got almost the same thing. Even with the key to acc. when I first press the pwr button the rear speakers hum. It slowly disappears, but will do it again if I turn the radio off then on again.
    If the car is running for a while it will do it constantly. The sound changes with the use of electrical things in the car.
  5. mustanggt94 Member
    Feb 22, 2002
    Message Count:
    643
    Indianapolis, IN
  6. bjl95mustang Founding Member
    Jan 18, 2000
    Message Count:
    1,503
    36
    Austin,TX
    When you isntalled you radio did you put an in line converter to turn down the power going to the mach 460 amps?
    This is what I did after i installed my hu 4 years ago and I havent had any problems.
    The install was easy. First you need to go to Best Buy install bay and get a wiring harness (About $10-15) for a MACH-460 and the inline converter ($35-50 I cant remember the price) this will allow you to turn the output power from the head unit down so it wont hurt the amps. Then go to www.flemworld.com and get the wiring diagram it is under 95 mustang. Once you get all of this stuff you will be set. To hookup the speakers there are the 1or2 (I cant remember) square connectors they are the feeds to the amps this is where you will put the inline converter. Then there is a long connector this is the power and amp turn on (don't forget this one) and stuff like that. To set the converter out put turn it all the way down and turn the stereo 3/4 up then turn the 4 knobs evenly all the way until it starts to distort.
  7. AznStanger3v Active Member
    Aug 11, 2003
    Message Count:
    2,033
    46
    Northern VA
    interesting. another one of fords shortcuts: crappy wiring
  8. SuperDust22 The Power of Pixie Dust?!
    Oct 19, 2003
    Message Count:
    1,840
    Gilbert,AZ
    That's funny I have had this problem forever. I need to read that thread.
  9. Gone2 New Member
    Feb 19, 2004
    Message Count:
    33
    It WAS the connection behind the drivers kick panel. I'm not sure which one exactly because I had "fixed" it before I took the panel off. I think it was the one with the very large grey wire that was almost on the floor board.
  10. DFG 5OH New Member
    Aug 28, 2004
    Message Count:
    1,349
    Kentucky
    Mach 460 Wiring Diagram
    I really need a wiring diagram for a 94 Mach 460. I have engine noise in my speakers, and its driving me crazy. I dont know what the problem is, but i hate not having any music.
  11. viperos New Member
    May 20, 2003
    Message Count:
    2,952
    Bellevue, WA (yes, the land where every 16 year o
    re check all of your grounds... and then the alternator... that's my guess.
  12. DFG 5OH New Member
    Aug 28, 2004
    Message Count:
    1,349
    Kentucky
    I had noise in my Mach 460 also, but i fixed it a few days go. Behind the drivers side kick panel, where the hood pull is, there is a sandwich plug. That plug had come loose, and had come corrosion inside the connectors, so i cleaned the connectors, and put it back together. i wrapped it in metal duct tape, and reattached it to where it went, i also cleaned up the ground behind there, and that fixed my problem.
    -Matt
  13. 5.0 from 95 Founding Member
    Nov 6, 2001
    Message Count:
    751
    Emory, TX
    Most all problems with whine are from grounds. One other thing to check is the cables running through the underside of the dash and when you brake the car it rubs the cables. The connector you put in, did it have a place to ground it? If you grounded it, take it loose and see if it still whines. If you didn't ground it, try grounding it. Some adapters work better with them not being grounded.
    Paul
  14. raginbul469 Founding Member
    Oct 24, 2001
    Message Count:
    160
    michigan
    another thing u can check is if there is nooise when the car is running u can havea weak cell in the battery or a bad sparkplug wire.
Share This Page
