Power Locks not working
I have a 2005 GT and all of a sudden my power locks don't work. I noticed when I opened my door and the alarm went off. Which means that when I locked it with the remote, the alarm sets but the doors do not lock. The buttons on the inside will not even lock the doors. I have to manually push the little bars down to keep somone out of my car. When I push the switch on the door, it makes no noise or even attempt to lock/unlock. Seem like there is a fuse blown but there is no fuse for power locks on the inside fuse panel or outside. What the hell is going on? :shrug:
You need to check the under hood fuse box fuse #62 20 amp if thats not blown I hope you have an extended warranty because it most likely the Smart Junction Box those arnt cheep.
Has the carpet on the passenger side front ever been wet?
I take it both inside door lock switches don't work.
the #62 fust was blown.........that was def the problem. Now here's the new delimma..........The passenger door will not lock automatically. When I lock the doors with the remote, it doesn't lock, when you press either side's button on the doors, it will not lock.......When I reassign the remotes to the car, it will not lock....any ideas?:mad:
