Power windows
Discussion in '2005 - 2009 Specific Tech' started by AdrenalineRush, Aug 9, 2005.
  1. AdrenalineRush New Member
    May 5, 2005
    Message Count:
    18
    Did anybody eared about a trick with the remote control (doors lock/alarm/trunk) that would open the windows before you get in the car?
    Thanks!
  2. 05Stangster New Member
    Mar 31, 2005
    Message Count:
    113
    Ha ha. That's a good one :) Here we go again :)
  3. bigcat start with the upper hole, and if more traction is
    May 2, 2005
    Message Count:
    4,250
    78
    ok, it WAS a feature of the first 05's to roll off the line. if you have a early production date and the active alarm, then you could try it. if not, dont waste your time. ford stopped this feature due to windows rolling themselves down. to operate it, i think you hold the unlock button. but again, MOST PEOPLE DONT HAVE THIS FEATURE!!!
  4. subzero05 New Member
    Dec 21, 2004
    Message Count:
    191
    I've got it!...With the doors locked hold the open button down and if you have it the windows will rol down.Also if you use your key to lock the doors when you turn the key to the right hold it there and if your windows are down they will roll up
  5. bat24 New Member
    Dec 28, 2004
    Message Count:
    66
    i had it but had it disabled . windows would come down at randiom even when the car was locked ford said water was getting in the locks after people were washing there cars causing the switch to close so rather then trying to fix it ford just disabled the feature ok by me security is more important sorry about my spelling
  6. frdtch05gt New Member
    Apr 12, 2005
    Message Count:
    9
    Mine has that feature, it has been working flawlessly and comes in handy.
  7. AdrenalineRush New Member
    May 5, 2005
    Message Count:
    18
    Thanks guys! I'll try it because mine is effectively an early prod...and i'd really like it to work because it's so hot in there when you leave it in the sun!
    Have a good day!
  8. born2run74 New Member
    Apr 3, 2005
    Message Count:
    SWEET! I have it too! My car was built in Sept 2004. This was the first I've heard about it...
  9. GT-03 New Member
    Dec 12, 2003
    Message Count:
    631
    Don't forget you have to have the factory alarm option too.
  10. AdrenalineRush New Member
    May 5, 2005
    Message Count:
    18
    :mad: Yeah well...disabled option. I'd really like it.
    :damnit:
  11. spectre30075 New Member
    Nov 17, 2004
    Message Count:
    39
    Awesome! Mine does it..had no idea. Was built in April of this year..I thought the feature was disabled before then?
  12. Johnnygreen Banned
    Aug 10, 2005
    Message Count:
    Haha..can't way to try it :cheers:
  13. Zodiac New Member
    Dec 17, 2004
    Message Count:
    248
    Did ford remove the option entirely, or just disable it off the line? If so, couldnt you have them reactivate it?
  14. bat24 New Member
    Dec 28, 2004
    Message Count:
    66
    its just disabled the trick is finding a dealership that will activate it
  15. biznazion New Member
    Apr 2, 2005
    Message Count:
    15
    There's been a number of posts on other boards about this and if I understand correctly there's actually a module that changed. There are people with post april build dates that have tried to get it enabled but it still doesn't work. I believe you can lock both driver and passenger doors with the key turned to the right, then you can have the global window feature re-enabled. If only the driver door locks when you turn the key to the right, you are totally out of luck.
Share This Page
