Problems with 2.3 staying running
Discussion in '2.3L (N/A & Turbo)' started by Ciara99, Jul 28, 2009.
  1. Ciara99 New Member
    Jul 28, 2009
    Message Count:
    12
    I am new to this forum since this is my first 2.3. Problem is that the car starts and idles. If you put it in gear it dies, also if you let it idle long enough it will start shaking, sputter, cough and die. It also spit out like black carbon out the tail pipe. I have replaced plugs, wires, dist cap, and pressure regulator. Another question is do you need a special wrench to tighten dist or just try to fit my hand down in there? Any help would be great. I bought the car like this and trying to fix it with out pouring money into randomly replacing parts. Thanks
  2. rd Founding Member
    Jan 12, 2000
    Message Count:
    3,287
    58
    Ocean Springs MS
    I would pull the codes before doing anything. The country boy jumper wire method and some careful counting will work in a pinch.
    Based on the above, I replaced the MAP or baro sensor on my 89 2.3 a couple years ago and cured a similar problem.
  3. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,498
    78
    Morgantown, WV...where couches meet their doom
    What do you mean by "pressure regulator?"
    And, the distributor bolt is hard to reach. You need a socket, universal joint, and then a long extension to reach it. Can't remember the size off the top of my head.
  4. 90mustangGT I felt sorry for girls because
    Jan 16, 2002
    Message Count:
    6,506
    9
    78
    Dallas, GA
    Slow IAC would be what I would look at first.
  5. Ciara99 New Member
    Jul 28, 2009
    Message Count:
    12
    I changed the fuel pressure regulator. It was bad and it at least starts everytime now just not for long. Also what and where is the IAC? I should have a code reader this weekend so I can pull some codes. Thanks for the help.
  6. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,498
    78
    IAC is mounted to the back of the throttle body. Looks like a cylinder about 4" long or so and has some wires plugged into it.
    Does it rev up ok?
  7. Ciara99 New Member
    Jul 28, 2009
    Message Count:
    12
    When I start the car it idles fine and reves up, but after a minute or two it starting coughing and shaking then dies.
  8. Dr_EluSivE Founding Member
    Apr 24, 2002
    Message Count:
    2,387
    56
    Central Illinois
    I would check the timing..
    Dr.
  9. Ciara99 New Member
    Jul 28, 2009
    Message Count:
    12
    The timing is set correctly and I also changed the fuel filter. It still starts and runs for about 30 seconds then it acts like it just shuts off, like you turned off the key.
  10. blakmustang93 New Member
    May 25, 2005
    Message Count:
    Portland,Or
    It might be the catylitic converter. I had a similar problem on mines until it completely plugged up and car wouldnt run at all check it out see if thats your issue :nice:
  11. Rcdriver45 New Member
    Aug 2, 2009
    Message Count:
    20
    Italy TX
    mine only idles at 1250-1500 rpm any lower and it dies or if i put it in gear it dies why?
  12. Ciara99 New Member
    Jul 28, 2009
    Message Count:
    12
    How do I check to see if the cat convertor is plugged up?
  13. Rcdriver45 New Member
    Aug 2, 2009
    Message Count:
    20
    Italy TX
    is that the problem?
  14. blakmustang93 New Member
    May 25, 2005
    Message Count:
    Portland,Or
    I thought mines was the cat. turns out its a couple hoses that are airlines that wore out along with some kind of piece that goes along the transmission... sorry i cant be much help cost me 75 at my mechanic to fix it car runs like a champ again.:D
Share This Page
