Ok I've got a used prochamber. I did buy new nuts and bolts to replace the old ones, but didn't buy any new studs for the stock "header" where it meets the prochamber. I've already determined it would be a b**** to get those off. I will buy new nuts though. Is it really THAT hard to work the connections between the midpipe and stock manifold? Another question..I know it's recommended to buy a new OEM gasket for the passenger side, but as far as I know the driver side is ball and joint..so do I need anything here at all or just bolt it right up? Also should I use locktite on any of these bolts for a stronger hold?
Also..will I just be removing 2 O2 sensors..one on each side? Looks like you will unscrew these with an open ended wrench maybe? I haven't gotten a good look at them. Thanks
