programming wireless remote
Discussion in '94-04 V6 Mustang' started by slow2.3, Dec 29, 2004.
  1. slow2.3 New Member
    Apr 15, 2004
    Message Count:
    30
    I currently bought a 99 stang. The guy only had one key and was missing the wireless door unlock remote. Is it possible to buy one from ebay and program it to my car myself?
    Thanks
    Derek
  2. marvinmycat Founding Member
    Feb 13, 2002
    Message Count:
    1,185
    Programming the key fob isn't hard, but I don't have the instructions in front of me so I can't say how easy it is for just anyone to do it, butI know a dealer can for a fee.
  3. telmd New Member
    Jan 14, 2004
    Message Count:
    34
    I was able to find out how to prog one for a 2002 grand marquis by doing a search in yahoo. I'd give that a try. Also a lot of times when you buy one off ebay the seller will have the instructions on how to go about programming it. Like previous poster said it is really simple. With mine i just had to turn the key on and off a few times to get into program mode
  4. mykltn New Member
    Dec 21, 2004
    Message Count:
    Put the key in the ignition but do not start the engine. Turn it to accessory and back 12 times very quickley. You will see the doors lock & unlock. Press any of the buttoms on the new remote and it will program to the car. You can program more than one remote at the same time. Good luck.
  5. Gr0und_Fault New Member
    May 27, 2004
    Message Count:
    113
    That sounds like it may work for a factory system. But what if it's an aftermarket system? Do you think the same would apply?
  6. marvinmycat Founding Member
    Feb 13, 2002
    Message Count:
    1,185
    Ford keys and Fob's are made by Ford. That is what you should be looking for. If it gets too frustrating, I paid $75 for an extra key and FOB from a Ford dealer, includes programming.
  7. Force Fed Flesh New Member
    Jul 24, 2003
    Message Count:
    does this apply to fords in general or just the mustang.....also is that a common method used by other car makers?
  8. mykltn New Member
    Dec 21, 2004
    Message Count:
    Not sure if it works on all fords or not. I had to reprogram my remote twice and the dealer wanted $25 to do it. I found the program instructions online and I worked perfect for my mustang.
  9. mykltn New Member
    Dec 21, 2004
    Message Count:
    If it is an aftermarket system that copies the OEM ford system then it should work. If it is just an aftermarket remote door lock like they have on car alarms then I would check with the manufacturer.
  10. Lsredy2kstang Look, I'm special, dammit
    May 13, 2000
    Message Count:
    2,798
    Uh, did you guys think of actually looking in your car manual. It is in there! That is just for the Remote though.
    Now the key is a different story. If you only have one key you are out of luck. you will have to pay FORD at least a minimum of 30 minutes to go into your computer to reprogram the security setting to accept another key.
    You could do it fine if you had two keys but since you only have one you will have to take it to FORD.
  11. Ghostalker New Member
    Jul 6, 2003
    Message Count:
    189
    phew, so lucky to have a 95'... lol :D :nice: :banana: :spot:
  12. mykltn New Member
    Dec 21, 2004
    Message Count:
  13. marvinmycat Founding Member
    Feb 13, 2002
    Message Count:
    1,185
    Laser was referring to us, and no one here looking in one of OUR manauals.
Share This Page
