Question?
Discussion in 'Saleen' started by Mark Cubberley, Oct 1, 2006.
  1. Mark Cubberley Founding Member
    Sep 23, 2002
    Message Count:
    216
    Tennessee
    Have any of you with 95 S-351's had the speedometer quit working? I checked the fuses and they are OK! ( I put insurance on it for 3 months and have been driving it again. I took it to a show last week and on the way home it quit working!) Thanks, Mark
  2. FASN8N New Member
    Nov 17, 2004
    Message Count:
    518
    Atlanta, GA
    Seems like their is a motorola chip inside that converts the speed so the speedometer reads correctly. Maybe the chip is faulty?
  3. marcus95 New Member
    Jan 27, 2004
    Message Count:
    2,148
    California
    Mark,
    It is the speedo drive wire at the connection on the Tremec. It usually goes intermittiend but sometimes just stops working. I doubt you will be able to visually see anything wrong there but that is the problem. 100% certain. Also, is your odometer working but not the speedo or the whole wack? Most of the time the wire about 4-5 inches from the plug ( probably grey ) on your car is the culprit. There may even be a homemade Saleen splice there wrapped in electrical tape.
    The conncetion just above the driveshaft almost on top of the trans on the drivers side.
  4. Mark Cubberley Founding Member
    Sep 23, 2002
    Message Count:
    216
    Tennessee
    Thanks guys! I am going to check and make sure the odometer is working! I think it is still working! I will let you know!! Thanks again! Mark
Share This Page
