QUICK QUICK OIL QUESTION--00 GT
Discussion in 'SN95 4.6L Mustang' started by SVT32VDOHC, Jun 6, 2004.
  1. SVT32VDOHC waiting for the next hack atta
    Nov 23, 2001
    Message Count:
    4,412
    What type of oil is recommended in the owners manual or the tag under the hood for a 00 Mustang GT 4.6L. 5w20 or 5w30
  2. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
  3. twogts4us Advanced Member
    Apr 2, 2004
    Message Count:
    4,084
    68
    5w-20 on our 01 and 02 and I'm fairly certain the 00 would be the same. Mobil 1's recommendation, to substitute for Ford's recommendation, is Mobil 1 0w-20. Just a little added FYI...
  4. 00BlackBeautyGT New Member
    Oct 5, 2003
    Message Count:
    298
    For 2000, 5w-30 is what is recommended. That is what I use.
  5. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    ya, ford switched in 2001, so therefore on the 2000, you use 5w30.
  6. smokin'Red35th New Member
    Jan 9, 2004
    Message Count:
    525
    not to hijack, but how bout a 99?
  7. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
  8. streetstang03 unModerator
    Dec 27, 2003
    Message Count:
    2,485
    99's call for 5w-30 as well. I use 5w-20 in my 00GT (Mobil 1). the engine blocks were changed in 01 and call for 5w-20 since the ports in the engine were smaller and 5w-30 is harder on the engine since it has to push a thicker oil through smaller ports. at least thats what i've learned/heard while working for Ford :shrug: all the newer engines (01+) used in the Ford vehicles call for 5w-20
  9. 40th GT New Member
    Apr 7, 2004
    Message Count:
    935
    Really? I thought Ford changed the oil requirement only for CAFE reasons.
  10. rjstaaf Founding Member
    May 31, 2002
    Message Count:
    1,309
    I would take anything you hear in the dealership with a grain of salt. I certainly wouldn't consider it as the best place to learn about your car :D
    I believe what you are thinking about is that 99-00 Mustangs used the Windsor block whereas 01 and up use the Romeo block. The Romeo block was also used prior to 99. When Ford designed the 4.6 and started putting it in cars way back in 91 they specified 5W-30 for it and continued to do so until 2001. The purpose of the modular motor is that parts are interchangeable. Don't you think a change in tolerances would affect this interchangablity?
    If you look at the TSB Ford issued in 2001 the ONLY thing mentioned is fuel economy, nothing else.
  11. Venom_Nitrous Founding Member
    Aug 23, 2002
    Message Count:
    419
    my 2000 calls for 10w30. Why :shrug:
  12. stangGT97 New Member
    Dec 22, 2004
    Message Count:
    1,405
    32
    you're special :nice:
  13. Dragstr05 New Member
    Dec 22, 2004
    Message Count:
    652
    2000 is 5w30. Ford switched to 5w20 for fuel economy reasons. You could have a 2001+ and use 5w30 and it will not hurt it, but you might see a slight reduction in fuel economy.
  14. Skidzz Tinkerbell
    Apr 12, 2005
    Message Count:
    687
    18
    I've been using Mobil 1 10w30 with no problems. Don't worry about it 5w30 or 10w30 is fine.
Share This Page
