quick ? sc
shttygtstang
978
ok ive been reading the threads and im still not to shure are the 94-95 motors the same as the super coupes. motor besides weaker internals. are the heads the same ? does this stuff bolt right up if you have all the brackets>
if so can the sc setup be swaped over along with the maf,injectors ,intake manifolld etc.....
i ask because im getting a v6 sn95 for a 460 swap ..but the swap wont start for maybe 6-8 months so ide like to beet the life out this motor till the swap starts ....
the entire rotating assy in the sc engine is better for obvious reasons. the heads appear the same, although they probably have slightly differently tuned runners for the supercharger. :banana:
i have a 97 3.8L, 84 3.8L, 86 3.8L, and a roller 3.8L Supercoupe engine that will be the replacement for my 86. this is such a great engine, but yes all the accessories and bracketry will bolt right up. all 3.8L RWD's are the same, save for cfi/tb/efi set ups.
also, if you have 5L front accessories/bellhousing they will bolt up, as the 3.8L is virtually identical to the 5L, minus 2 cylinders.
good luck with your torque monster BB. :cheers:
ya i dont care abought port sizes and hyper pistons vs forged . Or nickle content in blocks . I just wanna know intake will bolt up along with all the idler pulies ect for the sc .... I just wanna make shure its a direct bolt on with no fabrication.
Thanks for all the info
