Race Head????
Discussion in '2.3L (N/A & Turbo)' started by t3-svo, Jan 18, 2006.
  1. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    Mooresville NC
    Anybody heard of a company called Johnson's Race Engineering? I have a friend who has one of their 2.3L Heads with one of their cams insalled already. DOn't know tehe specs on the head or the cam.
    They do not give specs for their cams says my friend. Think it would be good for my 86 SVO?:nice:
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    No
    Is it even for a turbo motor? I'd guess it's for circle track racing in which case the cam would be a horrible choice (as would the head).
  3. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    Mooresville NC
    it was for a circle track car. why would that make the head itself a bad choice? I can get rid of the cam and get a turbo cam.
  4. mr_woodster Active Member
    Jul 28, 2003
    Message Count:
    1,316
    36
    Riverside, CA
    Most circle track heads are shaved ALOT for compression and are setup to flow well at HIGH rpm, not exactly streetable.
    Turbo = low compression
    N/a = High compression
  5. Sonicpony New Member
    Dec 12, 2004
    Message Count:
    92
    Mooresville, NC
    Duh, save ur $
  6. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    Mooresville NC
    just checking.... thanks
  7. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    Mooresville NC
    i have an oil leak that i believe is coming from my head gasket. it is leaking near the water pump area. if i need to replace the gasket then i will jut put a new head on it. ported and polished with a turbo cam. know anyone with a head for sale. or if i get a new head what should i get. any suggestions?
  8. RustBucket New Member
    Jun 8, 2003
    Message Count:
    585
    Buford, GA
    I dont' think that's a head gasket leak. It's probably either a valve cover or camshaft seal leak. Check those first. They're both pretty easy.
  9. samickguy15 New Member
    Sep 1, 2005
    Message Count:
    403
    Delavan, IL
    I love that. Problem = leaking head gasket Fix = new head I wish I had that kind of cash. I suppose if you were planning on doing the new head sometime soon it would be appropriate though...
  10. SVO1 Lord of The somethin' somethin' somethin', hell, I
    Oct 25, 1999
    Message Count:
    4,598
    Lord of uh, hmm what was it again?
    I would pony up and get an Essy aluminum head if that's what you are really wanting to do. (lose weight and be less crack prone than a stocker.)
  11. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    Mooresville NC
    i don't have that much money to spend to get an all aluminum head. But i have enough to get a castiron ported head. on the other hand i have already replaced the valve cover gasket last week due to the oil leak.... it is not coming from that. it is the cleanest part on the motor!! haha. i have used gunk foaming cleaner to clean the whole engine and i let the car sit ad idle for 30 minutes before i saw a leak.. it is very small near the timing belt. about the middle of the engine area.. just to the right of the thermostat housing.. any ideas?
  12. samickguy15 New Member
    Sep 1, 2005
    Message Count:
    403
    Delavan, IL
    Sometimes you can have oil permeate it's way into bolt holes through porosity in the casting. Possibly coming from the thermostat bolt??? Otherwise, I would say cam seal. You wouldn't have to remove the head for that, unless you wanted to.
  13. RustBucket New Member
    Jun 8, 2003
    Message Count:
    585
    Buford, GA
    Not from the thermostat bolt. That would be water. :) There's an oil galley plug just above the thermostat housing to the right. It takes and allen wrench to remove it. They seldom leak, but there's a first time for everything. Take it out, wrap some teflon tape around it or some slop some thread sealant (pipe dope) and thread it back in and check again for leaks.
    Keep this in mind, there's very little oil running around in that area. There's the galley I mentioned above, and other than a drainback hole on the passenger side close to the front, that's about it. The oil drainback hole is not under pressure so I don't think you'd see the kind of leak you're seeing from that. The only other spots under pressure near there would be the cam seal and aux shaft seal but it's over to the right of the water pump and down a bit. The cam seal being right above the water neck would be my best guess even before the galley plug.
    I went out and checked the D-port head I've got sitting in the garage and couldn't find any other bolt holes that are threaded through to an oil passage on the front of the head.
  14. RustBucket New Member
    Jun 8, 2003
    Message Count:
    585
    Buford, GA
    Well I was looking at the head again and found another place that may be suspect.
    The bolt that holds the tensioner spring, not the one that goes through the srping, but the one with the stem on the head that holds one of the spring fingers, threads through at the bottom of the valvetrain floor. Its possible that oil could be coming from there. Have you done a timing belt recently?
    Sometimes people (myself included) forget to put thread sealant on that bolt.
  15. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    Mooresville NC
    no haven't done a timing belt but need to soon. i can see very finite linds in it. i will check tomorrow in the daylight on the motor. will keep posted and thanks for all of the help.
  16. Sonicpony New Member
    Dec 12, 2004
    Message Count:
    92
    Mooresville, NC
    is there any kind of seal behind the crank pulley ?because it looks like that pulleys is throwing oil on everything in the engine bay
  17. RustBucket New Member
    Jun 8, 2003
    Message Count:
    585
    Buford, GA
    Yup, sure is.
  18. Sonicpony New Member
    Dec 12, 2004
    Message Count:
    92
    Mooresville, NC
    how hard is it to replace, i know u would need a crank puller and the seal is probably pretty cheap
  19. t3-svo New Member
    Apr 19, 2005
    Message Count:
    76
    Mooresville NC
    Finally heres an update guys... It turns out that sonic is wrong... haha it is actually the camshaft that is leaking. it is a very slow leak and it only comes out while the engine is running. very fine took an hour to spot it while it was idleing. is it hard to replace the seal there? IS there a possibility of messing up the timing? any tips? appreciate all the help!
  20. Sonicpony New Member
    Dec 12, 2004
    Message Count:
    92
    Mooresville, NC
    theres no way its just 1 leak, ur dreaming:notnice: looks like a 50 gallon drum of sludge blew up in there!
Share This Page
