radio help
Discussion in 'Mustang Sound & Shine All' started by Notchbck88, Apr 7, 2005.
  1. Notchbck88 New Member
    Dec 2, 2004
    Message Count:
    whats up guys i just put this head unit in my car about a month ago and it has been working fine until a couple days ago. when im in the car and not driving if i put the volume up to loud the display lights will go out and nothing will come out of the speakers unless i turn it off and back on again. if i start to drive it will go off everytime after a couple of minutes. when this happens only the display lights go out the screen stays lit up and it still has power
    when i hooked it up all i did was hook up the power ground and memory wires and the speakers straight to the head unit not the amp thats supposed to be underneath. anyone got any ideas for me?
    thanks
  2. VPStang Founding Member
    Oct 1, 2002
    Message Count:
    349
    bHAM, alabama
    Check your ground. Then after that recheck the ground. Then triple check the ground.
    In my experience ground is most common cause of all failure in stereo equipment.
  3. Notchbck88 New Member
    Dec 2, 2004
    Message Count:
    wouldnt the whole head unit go off if it were the ground? only my lights for the buttons go out the screen still stays lit and it keeps playing the discs but no sound
  4. eedwards New Member
    Apr 2, 2005
    Message Count:
    76
    NYS Albany area
    sounds like a short in the wiring kicking a circuit breaker, ok if reset. check to make sure all your connections are clean and can't touch anything else. sounds like maybe the vibrations of driving or high volume could be triggering the short. good luck!
  5. Notchbck88 New Member
    Dec 2, 2004
    Message Count:
    i just followed my power wire for the radio through my dashboard and it is connected with a yellow wire that goes through my steering wheel is that where the power wire is supposed to go to?
  6. DMDyne New Member
    Apr 11, 2005
    Message Count:
    43
    Warren, Ohio
    Yes, yellow is your constant power and red would be the memory. Black is always ground. What brand deck is this? It's my experience with JVC's that they have things like this happen often. Also, where did you buy the deck?
  7. Notchbck88 New Member
    Dec 2, 2004
    Message Count:
    its a clarion i got it from electronics boutique i just checked the ground and it looked ok but still when you turn the volume up past 25 the lights for the buttons go out and you cant here anything but the cd keeps playing
  8. DMDyne New Member
    Apr 11, 2005
    Message Count:
    43
    Warren, Ohio
    I think your best route of attack would be to check into any warrenty it may have and see if they can offer you a replacement.
    Clarion has a good reputation and shouldn't have many problems. If it's a motorized face, you may just have a bad ribbon and replacing it isn't very expensive. But have it checked first to find the specific problem.
  9. VPStang Founding Member
    Oct 1, 2002
    Message Count:
    349
    bHAM, alabama
    disconnect your radio antenna from the deck as well as the rca's and see what happens....
  10. Notchbck88 New Member
    Dec 2, 2004
    Message Count:
    cool thanks for all the replies guys i appreciate it
  11. Notchbck88 New Member
    Dec 2, 2004
    Message Count:
    actually when you do hit a bump or slam the door the radio will go right off would that be a short inside the head unit or in my car?
  12. DMDyne New Member
    Apr 11, 2005
    Message Count:
    43
    Warren, Ohio
    Could be a short behind the radio, in the radio, or in the fuse box. Many things could be the problem, ground, memory, constant....
  13. VPStang Founding Member
    Oct 1, 2002
    Message Count:
    349
    bHAM, alabama
    you could try routing your own power wires from another source--like the fuse box and ground it somewhere else.... This way you don't have to rely on the stock radio wiring...and then at least you will know if it's the deck that has the problem....but from what you've said...sounds like a short somewhere...
Share This Page
