Random cut-off problem
Discussion in 'SVT Forum' started by cradicg, Dec 21, 2006.
  1. cradicg New Member
    Oct 9, 2005
    Message Count:
    92
    Pennsylvania
    I have a gremlin I need help with. On three occasions over the last month, my car has stopped running on the highway. It didn't sputter and then die; I just suddenly notice the car is no longer running. This happens when I am approaching off ramps from the highway. The battery and check engine lights are all that come on, and there are no codes in the computer (I checked with my SCT). I have tried repeating various conditions (high rpm, high speed, sudden deceleration) but can not intentionally cause the problem. The only additional clue I may have was last night. I was approaching a stop light in town, and my idle dipped low (below 500 rpm) and the lights dimmed, but then it came back up. Could my idle be dropping too low to stay running on the highway? Like I said, I don't realize the car is no longer running until I try to slow down and turn off the highway (no power steering or brakes). The car immediately starts back up when I turn the car key. The vast majority of my car is brand new. Here is my current setup (all newer parts are less than 2 months old, if part is not listed, it's 1999 stock)....
    1999 Cobra coupe
    Ford Racing 4.6l DOHC crate motor (03/04 Mach 1 engine)
    JLT CAI
    SCT Xcal2
    BBK long tubes
    BBK catted X-pipe
    Magnaflow cat-backs
    Tremec TKO600
    SPEC aluminum flywheel & Centerforce clutch
    Ford Racing aluminum driveshaft
    Here is my last dyno sheet, red is after all the mods....
    <a href="http://photobucket.com/" target="_blank"><img src="http://i116.photobucket.com/albums/o6/cursed99cobra/8233.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
    Thanks in advance for any help!
  2. JLTucker New Member
    May 26, 2004
    Message Count:
    117
    Chesapeake VA
    At any speed above 55 this will happen. Your cramming air into the intake filter and closing the throttle blade. Now the air is bouncing back and forth across the MAF sensor and it doesn't know what to do.
    Best suggestion is to down shift. This is better for your brakes as well.
    Thanks
    Jay
  3. SVT98Snake New Member
    Apr 15, 2005
    Message Count:
    262
    OK, USA
    Hey Jay....what mods in your 03 got you to 517 aside from the JLT? Love mine BTW.
  4. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    Prattville, Alabama
    C'mon! Everybody knows that a full JLT CAI setup is guaranteed to give you at least 120RWHP! :eek: I hear the RAI is good for 100! :D
    Just kidding Jay! :rlaugh:
    U.M.
  5. SVT98Snake New Member
    Apr 15, 2005
    Message Count:
    262
    OK, USA
    I'll tell you what.....just the sticker is worth 50.
    j/k
    I did gain about 20 over a KN cone with Jay's kit. He even used my testimony on his site....so there. :D
    Great guy and service too.
  6. cradicg New Member
    Oct 9, 2005
    Message Count:
    92
    Pennsylvania
    Thanks JLT
    So is this associated with aftermarket intakes? I can't see the general public being OK with thier Mustangs cutting off once in while. I'll try the down shifting and see if that helps.
    On a side note, thanks for quoting me the individual replacement parts for my CAI. I will contact you after the holiday season to get what I need. At a minimum I need to replace the broken nipple. I will try to trim the split on the elbows since they are minor.
    George
Share This Page
