Ranger Cam
Discussion in '2.3L (N/A & Turbo)' started by Tru_Blue_104, Dec 17, 2003.
  1. Tru_Blue_104 New Member
    Nov 14, 2003
    Message Count:
    218
    Hey, I heard you can use a cam from a ranger in a 2.3. I only have a few questions:
    1. What year do I need to get this from?
    2. What parts do I need? (cam and what else?)
    3. How much will this cost?
    Thanks guys, I just heard that this was the cost effective way to go. If you got any other ideas, Id love to hear them. Thanks
  2. Dan'l Founding Member
    Aug 2, 2001
    Message Count:
    1,540
    cam,followers,lifters-$100 shipped to your door :nice:
  3. Tru_Blue_104 New Member
    Nov 14, 2003
    Message Count:
    218
    Thanks! But what year should I look to get it from? Does it even matter? Thanks!
  4. CruzNlife1 Founding Member
    Feb 18, 2002
    Message Count:
    1,419
    It depends on your current car.. 87-90 Mustangs can benefit from the ranger cam, which is a Roller cam and is ever so slightly more aggressive.. If you have the 91-93 Mustang, you already have the EXACT same cam in the rangers....
    To do the swap in your 87-90 you'll need the camshaft (obviously) and the followers... The roller cams in the rangers were from 93-00.. After 96 they became a little more aggressive, and after 2000 there is no more 2.3 like ours in the rangers... Just the new duratec DOHC 2.3.... Or you can get the exact same cam from a 91-93 mustang.... Good luck to you..
  5. Faux5.0 New Member
    Dec 2, 2003
    Message Count:
    17
    came in
    '89 - '94 or '95-'00
    the followers are not interchangable, the later ones have a narrower slot for the valve stem tip.
    The early/cast followers are made for use with the valves having 11/32" dia stems (all single plug and early DP heads prior to '95). The late/stamped followers are made for the '95-up DPH's with the 7mm-stem valves.
  6. Dan'l Founding Member
    Aug 2, 2001
    Message Count:
    1,540
    My offer still stands, $100 to your door(continental U.S.) :nice:
  7. Tru_Blue_104 New Member
    Nov 14, 2003
    Message Count:
    218
    Oh, you have that and youll send it to me for $100? Nice. I am of course in the US. PM me, I am interested. Condition?
  8. Mike SVOR Founding Member
    Mar 28, 2000
    Message Count:
    652
    Don't forget to put new springs on or grab the springs off the donor head
  9. CruzNlife1 Founding Member
    Feb 18, 2002
    Message Count:
    1,419
    why??
  10. Mike SVOR Founding Member
    Mar 28, 2000
    Message Count:
    652
    Roller cams use higher spring pressures due to their increased ramp rates.
  11. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    Hey Mike Svor you once said something about the ranger cam not being all that, I forget everything said. I was wondering I got a 93' 2.3L which already has a rollercam in it. What would be a upgrade cam for this and still be street able? It's pretty much a stock 2.3L with a A4LD ( yes the A4LD is about to go and the DP-DIS engine will be built to with stand a turbo install). This guy said in a few post back that the ranger cams get a little more agressive the newer they get, can I get one out of like a 96' and get a few hp and some more rpm's?
    Thanks
    P.s The feed on your 2.3 turbo racing the Fire bird was awsome. :hail2:
  12. Mike SVOR Founding Member
    Mar 28, 2000
    Message Count:
    652
    Thanks, that was a good run.
    I doubt that you'll even get 1 hp out of a newer cam if you already have the roller in there. The difference is so minimal.
    If you going to put a cam in, Put A CAM in. Eg. .500 lift or bigger.
    The head will flow that no problem with a little porting.
    Even without the porting, it'll be way better than the ranger cam.
  13. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    My cam isn't the ranger cam , all 91-93' 2.3L Mustangs came with a roller. Not sure if its the same grind as the ranger though.
    Do you got a part number for that cam? When I rebuild my 2.3L I will get the head ported, not sure on what they can do since its a twin plug but I will least get the ports cleaned up as much as we can.
    Thanks
    P.s keep the feeds comming is cool as hell :nice:
  14. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Yes it is...
  15. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    I worded that all wrong. I was trying to say is I didn't go off and install a ranger cam. In fact it already came with a roller.
    In a few post up a guy said the newer the rangers got the more agessive so I was guessing that the mustangs roller was a differant grind, thus being slightly different than the ranger's cam. So now I'm guessing at some point they may have been the same cam but switched to a different profile.
    Sorry. :D
  16. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    They have always been the same grind, they have always had the same ratio of followers...the newer followers aren't interchangeable though. A fellow TF member spec'd out both cams and followers and found the lift and other events to be identical.
    Stinger
  17. CruzNlife1 Founding Member
    Feb 18, 2002
    Message Count:
    1,419
    nope, rangerpowersports.com had a long thread about this.... after 96, the same time the trucks went to the new engine management system, they recieved a slightly different grind.. A wee bit more aggressive, they had the specs on rps, I can't seem to find them now though, it was a while ago...
  18. CruzNlife1 Founding Member
    Feb 18, 2002
    Message Count:
    1,419
    oh and by the way, don't bother, you would most probably never feel the difference.
  19. Pro-Hawk New Member
    Dec 5, 2003
    Message Count:
    990
    Thanks
    I guess porting the head is basicaly the only real thing to do besides a turbo.
  20. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    I'm alot more willing to trust and actual side by side comparison while taking measurements of the events than so called internet "specs"...unless that stands for "speculation" ;)
Share This Page
