Rear Proportioning Valve
Discussion in 'Mustang II' started by 1WildII, Jul 8, 2004.
  1. 1WildII New Member
    Oct 6, 2003
    Message Count:
    205
    How do you get the proportioning valve off the axle on a 76, thwe flex hose is cut and needs to be replaced, but it seems as though the hose is crimped inside, I can only assume that you have to take off the P. Valve off in order to replace this hose? Thanks in advance,
    Chris
  2. LedZ 5.0 now you have my pea brain going in circles
    Apr 1, 2004
    Message Count:
    207
    There's no proportioning valve on your axle housing. That's the brake hose and hard line junction block. Just remove the bolt on top of the brass block...should take a 9/16" socket. You'll get a new brake rubber hose with the new block. Be sure to disconnect your hard brake lines before removing the block bolt and plug the lines with a small rubber vacuum cap so you don't lose all your brake fluid. You will also need to bleed your brakes once you replace the rubber hose with brass block piece and hook up your hard lines. Also double check the vent hose that connects to the top of the brass block to make sure it isn't crimped anywhere.
  3. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    Good post.
    Sometimes a torch comes in handy for removal of frozen /difficult fittings.
    Also make sure the vent lines not blocked, You don't know if a creature built something in the breather because they were attracted by the smell. Hell, the smell of 90w-125 attracts human males.
  4. cobraii351 Founding Member
    Jan 10, 2000
    Message Count:
    1,096
    36
    I don't know about you guys but I ALWAYS move the brake line nut back and put Never-seize under the nut. Usually getting the nut loose is easy, but getting the line unseized from the nut can be the difficult part. That and whenever I put on new brake parts (calipers/wheel cyls. ) I remove the beeders and do the same. I hate fighting with little bolts that like to break off.
    Tim
  5. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    I Never Seize just about everything.
  6. cobraii351 Founding Member
    Jan 10, 2000
    Message Count:
    1,096
    36
    Yup, anything I might even think I want to remove again later. Especially the rack bolts through the bushings!
    Tim
Share This Page
