Replacement Intake Manifold
Discussion in '35th Anniversary' started by bubbajack, Nov 14, 2006.
  1. bubbajack New Member
    Nov 14, 2006
    Message Count:
    I have a 99 LE that is leaking coolant from the intake manifold. After doing some research, this is a common problem for this manifold design. Ford has been covering this on an extended 7-year warranty from the in-service date. Unfortunately, I am outside that 7-year window now and am looking to do the replacement myself.
    I can find "PI" manifolds and "Non-PI" or "NPI" manifolds with an aluminum crossover as replacement parts all over the web. Does anyone know which part to get? It appears that 99-04 4.6 engines would take the "PI" manifold, but I'm not sure. What is right part for the '99 LE? Thanks.
    Phil
  2. 35thspl New Member
    Nov 15, 2006
    Message Count:
    11
    texas
    My first post found about this forum from united stangs site.
    You want the PI intake due to the heads our cars have on them.
  3. bubbajack New Member
    Nov 14, 2006
    Message Count:
    I finally got the job done a couple of weeks ago. I bought a replacement manifold from a local Ford dealer. It did not come with replacement gaskets to go between the manifold and the heads. Some of the aftermarket parts appear to have the gaskets built-in but the factory part does not. It does have the upper gasket built-in where the plenum mates to the manifold. It also did not come with a replacement alternator bracket which is needed because the mounting posts are in different locations on the replacement manifold. I drilled holes in my old bracket which worked fine, but went ahead and ordered a replacement part that fit properly.
    Here's the details on the parts for anyone needing to take this on themselves; prices are from local Ford dealerships:
    Replacement OEM manifold with aluminum crossover:
    part # 1W7Z9424AB
    $352.32
    Replacement alternator bracket:
    part # 1R3Z10153AA
    Replacement manifold gaskets:
    part # YL3Z9439AA (this one has a tag labeled "R" for right side)
    $15.58
    part # YL3Z9439BA (this one did not have a tag designating the side)
    $14.33
    When I removed the old ones they were both the "**BA" part #. The gaskets are identical (whichever part # is used) as they are rotated 180° from each other when mounted. The openings and mounting holes are identical on each head.
    There is an online parts dealer that sells OEM parts for much less than the dealer: forddirectonline.com. I did not buy these there because I wanted them fast, but I have bought other parts there and they were factory labeled parts.
    Another place that claims to have the OEM manifold is karkraft.com; part # KK9424PI for $139.95
    I would recommend replacing spark plugs while you have it all disassembled as it will never be so easy to replace them at any other time.
    Phil
  4. rguercia New Member
    Dec 5, 2006
    Message Count:
    I'm having the same problem. The dealer first told me it was the thermostat housing. I replaced it and it is now leaking at the manifold. I wish I good afford to get it fixed, but hey, I'm a school teacher! Also, how much depreciation do you think having the entire driver-side replaced causes? Some idiot turned right into me causing me to do a few donuts. I've already had it repaired.
  5. bubbajack New Member
    Nov 14, 2006
    Message Count:
    Ford put out a 7 year warranty on this repair and it is based on the in-service date of your car. A dealer can look it up based on the VIN. My 7 years expired in July, so if the failure had happened 4 months earlier it would have been covered. Are you still in the 7 year window?
  6. rguercia New Member
    Dec 5, 2006
    Message Count:
    No. My 7 years hit in April.
  7. Kane Founding Member
    Mar 22, 1999
    Message Count:
    489
    Indianapolis, IN USA
    Yep. my 99 LE did the same thing...there was a crack in the thermostat housing and it leaked coolant. I paid for a Ford dealership to put a new intake manifold in the car with the metal parts...the way it should have been designed in the first place.
  8. madmatt Ellis Juan sympathizer
    Dec 28, 2002
    Message Count:
    843
    Lexington, SC
    I lucked out and mine cracked about 3 months before my window closed.
Share This Page
