Replacing rear speakers with small subs...
Redhero
157
Seattle
I need to trunk space, so Im taking my 2 10" subs out. DOes any company make subs small enough to fit in the rear speakers of a vert.? I can keep my amp mounted in the trunk if necessary, and have it still run the subs. Also...do the speakers covers just pop off? or is there a certain way I should remove them to get access to the speakers?
Thanks.
You want to replace your 6x8 with a woofer? What about a q form box? try crutchfield for the q forms. I would imagine that your not gonna fit much in the space for a 6x8. I just put 2 12's in my 97 and I still have room for groceries in the trunk. good luck
The most you are going to get in there is going to be a CRAPPY 6" sub, it is going to be crappy for 3 reasons
1. It is a 6" sub
2. For the mounting depth that you'll be alloted(sp?) it will have NO power
3. It will not be in any kind of enclosure, just free air.
I asked a local car audio place your question, and they said that you can put a 6" or 6 1/2 " driver in there, but those are considered mid range speakers anyway. They might sound better than a factory paper 6x8, but it is still only midrange. But it can be done!!! Personally I wouldn't even mess with 8" speakers, You can get some speakers that don't require much air space, and use a single 12 or something.
