Rough, loping idle...
Discussion in 'SVT Forum' started by Kilgore Trout, Nov 29, 2006.
  1. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    My Cobra idles rough.
    So far I have tried:
    -seafoam
    -changed plugs
    -cleaned MAF
    -reset PCM
    Is it normal for there to be a bit of roughness in the idle?
    Other things I am planning to try are:
    -new fuel filter
    -new x-pipe because I think my cats are clogged
    But maybe the lope is just normal for the engine??? :scratch:
  2. timeless2 Vi Veri Veni Versum Vicus Vici
    Apr 22, 2005
    Message Count:
    10,027
    18
    78
    It's not throwing any codes, right?
    Why would your cats be clogged with the low mileage you have?
  3. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    These engines do not lope with the stock cams. Should purr like a kitten. Haven't heard of problems with the stock cats getting clogged. This rough idle happens warm or cold at idle (approximately 750RPM's)?
    U.M.
  4. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    Clogged cats seems to be a pretty common issue people post about for 03s...
    The check engine light is not on.
    It does it when warm.
  5. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    I've rarely read about clogged stock cats on a STOCK '03. Seems if they were clogged though the down stream O2's would be throwing a code.
    U.M.
  6. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    What do you think is causing my idle issue?
  7. 68torinogt Hey guys, guess what--I have a bi-pass!!!
    Mar 21, 2006
    Message Count:
    490
    202
  8. STRTRENEGADE354 New Member
    Jan 15, 2004
    Message Count:
    10
    What did you use to clean the maf?
    And what plugs and what gap do you have them at.
  9. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    I used quick drying electrical contact cleaner spray to clean MAF.
    I installed Motorcraft AGSF-12FM1 gapped at .035
  10. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    You know this is a tech forum right? Keep that kind of "crap" in talk... :notnice:
  11. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    Well, I just recleaned the MAF and also cleaned the IAC plus I again reset the PCM.
    The idle still sucks :(
    Next up is a fuel filter, if that does not correct it I have a feeling it is gonna be something expensive to fix... $$$
  12. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    If you just recet the PCM, make sure you give the car at least a half-dozen drive cycles and see if it clears up. Did it idle rough prior to repacing the plugs?
    U.M.
  13. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    Yes, the idle is exactly the same as it was before I started doing things to attempt to correct it. Nothing I have done has had any effect on the rough idle.
    However, driving in to work this morning in the cold rain with the a/c on the idle was much smoother. Perhaps the fuel trims are re-learning to smooth it out. I will keep a close eye on it for the next few days.
  14. Uncle Meat Banned
    Jun 13, 2002
    Message Count:
    3,869
    I say give it a few more drive cycles before taking it in for professional help. :D
    U.M.
  15. Kilgore Trout Fried or Broiled ?
    Mar 31, 2005
    Message Count:
    8,280
    76
    Yeah, until I get my tax return professional help is not really an option... Christmas is killing me this year :(
    Thanks for the advice sir :flag:
  16. 68torinogt Hey guys, guess what--I have a bi-pass!!!
    Mar 21, 2006
    Message Count:
    490
    202
    im sorry,
    i suggest putting a scanner on it and pull off sensor info,
    we have a snap-on scanner and it gives tons of good helpful info.
  17. midlifecrisis99cobra Founding Member
    Jun 2, 2000
    Message Count:
    422
    My 99 has done the same thing since day 1. Slightly rough idle at about 750-800 rpm when warm. Idles smoothly about 850-900 when cold. Gets better for about 15 minutes after changing plugs then goes back to same old deal.
    I occasionally wonder about an injector/coil issue. Doesn't seem to be generating any codes.
Share This Page
