routing problem!
Discussion in 'Mustang Sound & Shine All' started by xYoung347x, Feb 16, 2004.
  1. xYoung347x New Member
    Nov 3, 2003
    Message Count:
    387
    **Warning** I don't know the technical terms to the audio world so please bare(sp?) with me. Also sorry for the poor gramar ahead of time.:);)
    I have 2 JL subs and Im having problems rerouting the big red wire that goes to the amp thru the car, thru the firewall and then onto the + battery because I just finished an AODE 2 Tremec swap which the clutch cable replace the big red wire hole that goes all the way back to the trunk. Where else can I get the wire back thru onto the inside of the car?
  2. gatzer New Member
    Jan 22, 2004
    Message Count:
    37
    I found a hole at the very top of the gas pedal. It was very easy to see from the engine side. It had a grommet in it. Just had to pull back the carpet to access it. If nothing else drill a hole. Triple check everything first before you drill. Good luck.
  3. 93GreenLX Founding Member
    Aug 22, 2002
    Message Count:
    780
    that's where I have my 0 gauge fed through also
  4. xYoung347x New Member
    Nov 3, 2003
    Message Count:
    387
Share This Page
