Shaking...Help
Discussion in '2005 - 2009 Specific Tech' started by burkey-44, May 9, 2009.
  1. burkey-44 New Member
    May 9, 2009
    Message Count:
    I own a 2006 Mustang Gt conv, just put on a new set of saleen style wheels from American Muscle, car is shaking really bad. Have had the wheels and tires balanced twice, last balance was a road force balance for 150.00, helped a bit but car feels like its from 1969. Any suggestions.
    Thanks
  2. mustangford289 Founding Member
    Sep 17, 2001
    Message Count:
    970
    28
    Florida
    Call
    Call American Muscle and get some help. Take it to a tire shop have them check the wheels. I have had good luck with AM, I'm sure they will help you out.
  3. mrv8outboard Member
    Mar 31, 2005
    Message Count:
    38
    Remove the wheels and check for the factory clips that go over the wheel stud that hold the rotors on. If they are there just remove them and try that.
  4. TestMe New Member
    Jan 15, 2009
    Message Count:
    28
    Lubbock TX
    check to see if there are spacers between the wheels. this will cause the car to shake at higher speeds
  5. SpartaPerformance StangNet Sponsor
    Nov 5, 2006
    Message Count:
    1,815
    38
    Long Island NY
    +1 for TestMe, just because the rims have the right lug pattern doesn't mean they fit the car properly. Check the hub vrs the hub hole on the rim if it's not a snug fit then you need hubcentric spacers, also you may need a different lug nut to square the rim onto the hub surface.
  6. stanmckinney Active Member
    Mar 31, 2005
    Message Count:
    1,180
    38
    Could put the original wheels back on and see if the car shakes. If it doesn't than it has to be a problem with the wheels.
  7. burkey-44 New Member
    May 9, 2009
    Message Count:
    Hey thanks for everyones help, mrv8outboard you nailed it. Stock Mustang rim has recessed flange, new rims do not. Mustangford289 American Muscle were great to deal with , one of the rims was barely in spec they sent a new one no questions asked. Great not to be shakin anymore.
    Burkey
Share This Page
