Shaking
Discussion in '2005 - 2012 Specific V6 Tech' started by Mafia Mustang, Nov 3, 2007.
  1. Mafia Mustang New Member
    Sep 18, 2006
    Message Count:
    111
    Arizona
    Hey Guys my 2006 V6 Mustang Has started a Shaking problem. I took it to the dealer ship and they said dirty injectors, but I want to get your opinons first. It shakes a little bit when I come to Stop lights, shakes a little more with the air on but when I get somewhere and put it in park it shakes really hard and feels like it may die. I just wanna get some opinons and see if anyone else has had a similar problem. Thanks guys/girls.
    Jen Lynn
  2. shooterm1 New Member
    Jul 19, 2005
    Message Count:
    546
    Milford, Pennsylvania USA
    dirty injectors sounds right / probably from crummy gas ...
    go get yourself some Injector Cleaner and run it thru with a few tank fulls of good gasoline.
    ps, I sometimes run a pint 99% Ethol Alcohol through mine to prevent that on mine.
  3. Jenns01TA Active Member
    Mar 31, 2005
    Message Count:
    1,112
    36
    Hey Jen,
    I concur with Shooterm. Dirty injectors and bad or fouled injectors are totally different issues. To rule out a failing injector, try adding 1/2 can of Sea Foam in a full tank of quality gas. You can get Sea Foam at Auto Zone and most other larger retail parts stores for $6.00 - $8.00 a can.
    Sea Foam is a 100% petroleum based product and has been around for decades.
    http://www.seafoamsales.com/motorTuneUpTechGas.htm
    You will be able to rule out dirty injectors versus a mechanically failing injector if it clears up after you run the tank nearly empty.
    Let us know how this works for you. It is a far cry better if your car is out of warranty to try this first than to spend $300 - $500 on new injectors when you may not need them.
    Injector problems can be confusing to diagnose and expensive to fix, unless you can do it yourself and even then injectors are not cheap. We have an injector issue on our 1998 Cobra right now that is really irritating me. lol :(
    Good Luck, Dear. :)
  4. Mafia Mustang New Member
    Sep 18, 2006
    Message Count:
    111
    Arizona
    Thanks Guys I went and Got some Sea Foam and ran it though and I noticed Much less shaking Still alittle bit though. I used a diffrent Injector Cleaner b4 and noticed no diffrence That Sea Foam must be some Serious stuff lol.
  5. Jenns01TA Active Member
    Mar 31, 2005
    Message Count:
    1,112
    36
    Indeed it is. Go easy on it. It is safe to use as described for a couple tanks. Pleased it worked. Sea Foam is the way to go. If you read the link it can be used in the oil and in the intake as well.
    It IS an outstanding product.
Share This Page
