Short Block Questions????
Discussion in 'SN95 4.6 Talk' started by MOMOMACH, Jan 6, 2009.
  1. MOMOMACH New Member
    Jan 6, 2009
    Message Count:
    Okay hears my pitty story….my 03 mach 1, which had a petite 29,000 miles under it’s belt, developed a knock in the engine…it’s a connecting rod….and it appears as if it’s going to cost me about $2000 when it’s all said and done to just have the bottom end rebuilt with stock components
    So this is what I was thinking….MMR makes a variety of 4 valve short block I can just about afford…. between $3000-$2500…I’m currently working my way through college and money is hard to come by, however, I’m not willing to sacrifice quality and I might as well have a strong platform for future upgrades…forged internals are a must for the power I plan on making a couple of years down the road…The only thing is the MMR blocks I can afford are all iron so I would be gaining some weight ditching my aluminum block
    So my questions are:
    Is MMR (modularmustangracing.com) the best company to go with for a short block???
    -How much more does a iron block weigh over the mach’s stock aluminum block???
    -For right now I have to use my stock heads, cams, and intake so would I see a initial power increase if I went to a 5.0 or a 5.4 over the 4.6???
    -What would be the most cost efficient way to get more power out of a higher cubic inch engine like a 5.0 or 5.4 if I do go with one in my mach????
    Thanks for reading and I really appreciate any suggestions
  2. mustangman9812 Active Member
    Jan 14, 2004
    Message Count:
    613
    26
    Mars Hill, North Carolina
    MMR is Deff the Best company to go with!
    The rest is up to you, maybe some 4v guys can step up and help with that, but you WILL NOT GO WRONG with MMR!!!
  3. BK_CAULEY it's built for speed not longevity, woman
    Dec 26, 2006
    Message Count:
    1,760
    36
    Thomasville, ga
    40 lbs, and if you plan on going with a power adder in the future stick with a standard bore and stroke.
  4. SaleenGT2001 Active Member
    Jul 19, 2005
    Message Count:
    2,925
    46
    Four Oaks NC
    stick with the 4.6 or 5.0 stroker.
  5. 02nightmaregt To hell with your Mustang, I want to see your HOG!
    Jul 1, 2007
    Message Count:
    638
    Southern Indiana
    +1 no more than a 5.0 stroker. MMR is a great company w/ an awesome reputation. You caould just offset the weight w/ a aftermarket K-member kit when you get some cash saved:shrug:
  6. TGJ New Member
    Mar 31, 2005
    Message Count:
    1,055
    Nice, you posted this in Tech and Talk sections.
    http://forums.stangnet.com/772878-short-block-questions.html
    Like I said earlier in the tech thread. MMR is NOT a good company, do a Internet search on them and you will find they have plentiful unhappy customers and many complaints with the Better Business Bureau. Not something you will find with a good reputable shop.
    5.0L Strokers are a huge waste of funds if you intend to stay N/A. You will make less power with it.
  7. 98GTfromGA Founding Member
    Mar 17, 2002
    Message Count:
    297
    Memphis
    Just buy a rotating assembly that is .020 over and have a local machine shop bore and hone your aluminum block and assemble it you'll be less than 3 grand that way
  8. Blackone51 Member
    Oct 31, 2008
    Message Count:
    200
    +1 on that
Share This Page
