side emblems
Discussion in 'Mustang Sound & Shine All' started by Jonseys Stang, May 14, 2004.
  1. Jonseys Stang New Member
    Jan 5, 2002
    Message Count:
    12
    Does anyone know how to remove the side emblems onthe front quarters without screwing up the paint under them?
    Thanks
  2. x2cstang New Member
    May 7, 2004
    Message Count:
    36
    Here at the body shop we use fishing line and run it underneath the emblems. Then all you need is some adhesive remover and it will clean right up. If you use 3M adhesive remover get the one that is NOT in the spray bottle. :nice:
  3. BZ's_03_SVT New Member
    Jan 20, 2004
    Message Count:
    81
    thats the way i have heard...but do you know if mustangs are like the F150 emblems with two holes in the quarter panel to line it up right?
  4. wytstang Advanced Member
    Mar 14, 2004
    Message Count:
    5,154
    76
    They do have two small holes to line up emblems
  5. UMDSmith New Member
    Feb 10, 2004
    Message Count:
    220
    Mine didn't have the holes, the way mine came off was using high pressure warm water from the presurized car wash, aim it directly down on the glue, not hte body, and it takes em right off.
  6. Phoenix00GT New Member
    Apr 27, 2004
    Message Count:
    270
    I've seen plenty of debadged mustangs running around and none of them have the holes to line them up...I will second the recommendation for the fishing line (or some similar)...then it just takes some really high pressure hot water or an adhesive remover...I've done this on other cars and the adhesive is a bit of a pain in the a$$ so plan on using some elbow grease
Share This Page
