some final questions
Discussion in '2.3L (N/A & Turbo)' started by 93pusstang, Jan 21, 2004.
  1. 93pusstang New Member
    Mar 16, 2003
    Message Count:
    228
    Kentucky
    ok im jus gonna ask some final questions before the swap in the next couple of weeks.
    1. will the clutch in my 93 5 speed work with a 85 svo motor?
    2. fly wheel? keep my current one or use a TC one?
    3 will my stock 7.5 rear end hold up to the 2.3t svo motor or will i need a 8.8?
    4. im sure my current ecu wont work with the svo motor, which ecu should i go for?
    5. BOV, which one should i go for? i hear bailey is a good one.
    6. what psi are the stock 85 svo motors runnin, they are 175hp/210 torque so im guessin around 8-9-psi and with a adj. boost vavle i think they can run upwards to 21?
    also a estimated price of each would be nice :D
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    1. Work? Yes. Suggested? No.
    2. Depends on which clutch you use.
    3. 7.5" is fine.
    4. 87-88 TC unit.
    5. Bailey, Forge, or other dual piston unit.
    6. 14.5psi stock, can run up to 24 with the right mods to support it.
    Stinger
  3. Crovax Type O Danzigative the Dark
    Sep 4, 2000
    Message Count:
    5,487
    9
    88
    Vinland
    1. Yes. You can use either. I romp the **** out of mine.
    2. Yes. You can use either. I romp the **** out of mine.
    3. Yes. You can use either. I launch the shi t out of mine.
    4. Whichever matches your injectors and vam size.
    5. Bailey.
    6. 15psi.
  4. 93pusstang New Member
    Mar 16, 2003
    Message Count:
    228
    Kentucky
    ok i got the motor today, but has no oil feed lines, where can i get these from?
Share This Page
