starting issue
Discussion in '2.3L (N/A & Turbo)' started by leserz, Jul 15, 2007.
  1. leserz New Member
    Jan 14, 2007
    Message Count:
    24
    tennessee
    it seems most of the time when i go to start my 86 with a 2.3, auto if that matters at all with a carb. when i turn the key to the start. it will start right up. but as soon as i bring the key to the run position its like i turned the engine off. takes 3-5 times before it will stay running. is there a dual pick up in the distributor ? or could it be the ignition switch or some thing else ?
  2. ethangsmith New Member
    Jan 29, 2007
    Message Count:
    227
    Manheim, PA
    I would still say it's your ignition switch. Classic example of one that is worn out. Your distributor has a "hall effect" sensor in it. It does not have a traditional "pick-up", but it is a sensor that sends an on-off-on signal to the computer. Power is supplied to the TFI module, hall effect sensor, computer, and all other computer-related items by the ignition switch. Sounds like the "run" position of the switch is failing, since it starts just fine, thus eliminating a failed relay of some sort. Since the ignition switch is a cheap part to replace, I would start there.
  3. Distortion 5.0 New Member
    Jul 8, 2005
    Message Count:
    140
    My 85 ranger did the exact same thing.
    It was a manual, so I was able to hold the key in START and release the clutch to disengage the starter motor.
    As soon as I would let go it died.
    It was the ignition switch on the ranger.
Share This Page
