Starting Questions
Discussion in '2.3L (N/A & Turbo)' started by toadstang, Feb 22, 2004.
  1. toadstang New Member
    Nov 16, 2003
    Message Count:
    79
    Okay, I replaced the head gasket and put everything back together. Got it finished up yesterday. Put oil in and coolant. Hooked the plugs and wires. Go to start it, it cranks over, but won't fire. I put the battery on a charger cuz it seemed like it wasn't getting enough juice, and went to start it this morning and again, no start, just cranking. (Yes, I have fuel :p ) I don't know what the problem could be, Im letting the battery sit on the charger again and Ill try it tomorrow. Does anyone have any other suggestions?
  2. toadstang New Member
    Nov 16, 2003
    Message Count:
    79
  3. ssjmaverick23 Member
    Oct 29, 2003
    Message Count:
    222
    have u checked the coil pack to see if its good mine went bad and my car would only turn over. also double check and make sure ur timing is tdc and that ur plugs are in the right order
  4. toadstang New Member
    Nov 16, 2003
    Message Count:
    79
    The car started fine before taking it apart, and I bought new plugs before restart, the other were caked in oil. The firing order and everything is right outta the Haynes manual. I took off the cap and wires as an assembly and marked them beforehand. TDC was set after removing the head, putting number one and four pistons at the top.
  5. toadstang New Member
    Nov 16, 2003
    Message Count:
    79
    I tried to start it again yesterday. It didn't work. I dunno, maybe my timing is messed up or something, but I did everything like the books told me. The guide pin is lined up with the timing marks. I did everything the way the book told me and it wont start. When I tried to start it, it just kept cranking. It actually sounded like it was running one time when I pushed my foot on the gas, but it died out as soon as I let off and it sounded horrible while it was "running." I dont know, I need help, any help will do. Its been three weeks, I need my car :(
Share This Page
