Steering Rack Removal
Discussion in 'Mustang II' started by 1WildII, May 27, 2004.
  1. 1WildII New Member
    Oct 6, 2003
    Message Count:
    205
    Ok excuse my lack of terminology, but I need help pulling off my steering rack and I think they are called tie rods :shrug: , where the steering rack connects to the spindle... is there any special way to get it out, because those things dont seem to budge and they are the only things left holding it on. Any help would be great, along with the correct name if I got it wrong. Thanks in advance,
    Chris
  2. IICrazy taken away
    Mar 28, 2003
    Message Count:
    1,415
    36
    This is probably what you need, which i believe you can rent from auto parts stores
    Tie rod seperator
    [IMG]
  3. 1WildII New Member
    Oct 6, 2003
    Message Count:
    205
    Cool, thanks for the help.
    Chris
  4. Blue Thunder Active Member
    Mar 20, 2004
    Message Count:
    1,081
    36
    (Also doubles as a tuning fork)
  5. dmoody Founding Member
    Nov 4, 2002
    Message Count:
    798
    Those tie rod separators are possibly the worst possible thing to use unless you are changing the tie rods... they always end up busting the grease pack. They make a tie rod puller which hooks around the tie rod then screws down on the end where the king pin/nut goes. That is what I would get if you want to reuse your tie rods. Check out "harbor freight tools" for great prices on tools that you don't use very often. Be forewarned however that nearly all of their stuff is made overseas.
    d
  6. 1970impala Please God, somebody find me some WHITE CARGO PANE
    Jan 22, 2002
    Message Count:
    1,448
    36
    CALLING TIM....COBRAII351...WHERE ARE YOU!!!! (he is the ultimate expert on these!!!) seriously.
  7. Blue Thunder Active Member
    Mar 20, 2004
    Message Count:
    1,081
    36
    An air hammer will loosen the rod end without hurting the parts.
  8. zwhitr Founding Member
    Aug 27, 2001
    Message Count:
    851
    I have never used any special tool
    just loosen the nut a few sharp wraps on the nut and its loose if that don't work get a bigger hammer :lol:
    ps. I like the air hammer idea --- thanks Blue Thunder
  9. Stang2Man Founding Member
    May 16, 2000
    Message Count:
    369
    just keep an eye on some of those harbor freight tools, they aren't always the best quality i've had some success with their stuff, but like was mentioned they're made overseas.
  10. Johan New Member
    Jun 13, 2003
    Message Count:
    81
    This type is very easy to use.
      File size:
      40.1 KB
      36
  11. 1WildII New Member
    Oct 6, 2003
    Message Count:
    205
    Man I was hoping I didnt have to buy a special tool! Ill try a few "raps" on it and see if it comes off, if not then Ill go get the tool that I will only use twice, or so im lead to believe.
    Harbor Frieght is sort of hit and miss with thier stuff, me and a friend bought a welder from them, lets say we got lucky because it still works, but I can tell they have some low quality stuff.
    Chris
  12. Stang2Man Founding Member
    May 16, 2000
    Message Count:
    369
    Auto Zone loans plenty of tools out and I'm pretty sure that the "snake tongue" that's what I've always heard it called, but anyway, that shoudl be on their loan-a-tool list you may wanna check on the website or just drop in your nearest AutoZone.
  13. rufus13 New Member
    Apr 20, 2004
    Message Count:
    I'm a automotive tech...My main job is front end alignments and front end work....
    Take the nut off and hit the end of the spindle with a large sledge hammer.....
    If you hit it a couple of times...the tie rod will pop right out...
    Warning....Do not do this if you are worried about slightly denting the end of the spindle arm...
    Works for me everytime......and its fast.....
    Just a suggestion.... :nice:
  14. Blue Thunder Active Member
    Mar 20, 2004
    Message Count:
    1,081
    36
    Yeah, I used to do that when I was still fixing cars for a living. It "ovals" the hole slightly. Looks ugly, but is effective.
  15. mcmmotorsports New Member
    Apr 12, 2004
    Message Count:
    693
    Always worked for me :nice:
  16. 1WildII New Member
    Oct 6, 2003
    Message Count:
    205
    ok I have succesfully removed it, I used the hammer trick and it came right out. Now does anyone need a power steering rack? Thanks for the help,
    Chris
Share This Page
