stereo install = guage problems
Discussion in '94-04 V6 Mustang' started by ezkartpro125, Jan 26, 2004.
  1. ezkartpro125 New Member
    Jul 4, 2003
    Message Count:
    24
    ok, i have a 2000 stang and it had the premium sound system, not the mach, but the factory one with a cd player, i just installed a new kenwood headunit, a jl amp, and a kicker solo baric sub, as well as new door speakers, man does it sound tight. but i have a problem now. ever since i installed the headunit, when i start my car, it takes like 20 seconds b4 any of my gauges start to function. i mean they are all off. no odometer even, then they turn on, the odometer flashes a bunch of wierd looking numbers and then it shows my normal mileage. any body know whats up?
  2. GREENBIOCH Founding Member
    Mar 23, 2002
    Message Count:
    1,247
    Do you have any under drive pulleys on your car?? Did you do install yourself?
    I'm just wondering if the system is draining the power on your car, if it is charging fully, like to much of a power draw or something like that. You should ask this question in the sound and shine forum, there is some good stereo peeps in there that would know what to do.
  3. doc4444 Founding Member
    Jul 11, 2002
    Message Count:
    235
    ezkartpro125:
    First off write down those numbers that flash. Then go talk to a Ford dealer. The numbers are probably a code letting you know what is wrong. Also note how many times the numbers flash, long flashes, short flashes, etc.... Also note exactly how long it takes before your gauges start. Armed with this information your Ford dealer should be able to help you out.
    Doc
  4. ezkartpro125 New Member
    Jul 4, 2003
    Message Count:
    24
    they arent really numbers though, its just a bunch of the little bars that make up the numbers... and it only flashes once real quick then it goes normal and all the guages power up.
  5. dastang2 Active Member
    Dec 12, 2003
    Message Count:
    2,058
    46
    did you unhook the battery while installing all of that electrical equipment.
  6. marvinmycat Founding Member
    Feb 13, 2002
    Message Count:
    1,185
    What everyone else said, plus you might want to install a power cap.
Share This Page
