Stroker Kit Question
Discussion in 'Fox 5.0 Mustang Tech' started by djk8705, Dec 25, 2003.
  1. djk8705 New Member
    Oct 1, 2003
    Message Count:
    154
    Fairfax, Va
    Im still learning everything here and I have some questions about stroker kits. I dont totally understand what you are doing when u make ur 302 into a 347 stroker motor. Are you just boering over the block to a certain degree and then puttting in larger pistons and crankshaft? If I wanted to turn my 302 into a 347 stroker what would I need to do and what would I need to buy ?? What is a average spennding price when ur all finished? I found a dss 347 stroker for 1000$ what else would be needed? ... Just learning here so any information would help me alot. Thanks
    Oh and what kind of power could I be looking at with a 347 stroker motor?
    thanks a lot
  2. TIMMY2734 Founding Member
    May 17, 2002
    Message Count:
    1,332
    Queens, NY
    For a stroker, you need a new crank rods and different pistons. The power that you make depends on your induction components
    Sponsored Ad
  3. djk8705 New Member
    Oct 1, 2003
    Message Count:
    154
    Fairfax, Va
    Okay, are u boreing out anything? or are they just "stroker" pistons and crank rods? .....
  4. TIMMY2734 Founding Member
    May 17, 2002
    Message Count:
    1,332
    Queens, NY
    for a stroker it isnt "neccessary to go .030 over or whatever. But sometimes it is required if the cylinders are not in the best of condition
  5. strtracer442 New Member
    Dec 12, 2003
    Message Count:
    175
    Roseville,MI
    Yes, the motor is bored .030 for a 347.Stroke is raised from 3" to 3.4"
  6. TIMMY2734 Founding Member
    May 17, 2002
    Message Count:
    1,332
    Queens, NY
    well i was talking strokers in general. not one specific cid
  7. djk8705 New Member
    Oct 1, 2003
    Message Count:
    154
    Fairfax, Va
    what is the typical price for haveing somebody boering ur engine, if You pullled it and brought it to them?
  8. giddyup306 Founding Member
    Oct 22, 2002
    Message Count:
    3,018
    The guy I go through charges $8 a hole.
  9. giddyup306 Founding Member
    Oct 22, 2002
    Message Count:
    3,018
    Mines in the area of 700-900 FWHP and 1200+ ft lb tq.
  10. strtracer442 New Member
    Dec 12, 2003
    Message Count:
    175
    Roseville,MI
    Mines 450 n/a stock block with girdle,and I intend to spray.
    I sprayed the stock motor at 150 and never broke any thing(oops a clutch)
Share This Page
