Supercharger Oil
Discussion in 'Saleen' started by ExtremeSaleen, Jan 14, 2006.
  1. ExtremeSaleen New Member
    Mar 31, 2005
    Message Count:
    236
    Just spoke with a Tech @ Saleen thru email regarding changing the oil in the supercharger as I've been getting conflicting information on when it should done.
    Saleen has a newer oil for the superchargers from "Nye" that is good for 50,000+ miles. You can purchase it straight from Saleen. Older cars though, like my 02, came with supercharger oil that should be changed every 3,000 miles. I know it was changed at 9,000, but I'm a little past due now.
    I don't know when they started using this new oil but I think 04. But if yours is an 02 or older, you have more then 3,000 miles on it, and you haven't changed the oil yet, you might want to.
  2. BlackSaleen New Member
    Aug 8, 2005
    Message Count:
    92
    Changing Oil every 3000 to 4000 on the supercharger miles seems a bit much. Joe from Chicane told me after he installed my Saleen Series ll that the oil didn't need to be changed for 100k miles. I doubt i will have my Saleen that long.
  3. Tommy98016 New Member
    Mar 17, 2004
    Message Count:
    90
    I have heard 50-100k myself but if you every add a smaller pulley to spin it faster I would change it once a year.
  4. C.Saleen New Member
    Jan 18, 2004
    Message Count:
    228
    sc oil
    i changed mine one time on my series 2, kb says every 12k they use 50 weight redline oil, i know the eaton's can use the gm sc oil, i belive you have a wipple tho, so you be best contacting wipple dirrectly, youll get more feed back from them then saleen, also over on modularfords.com, there is a wipple forum, you might also try there
  5. BlackSaleen New Member
    Aug 8, 2005
    Message Count:
    92
    Where is the drain and fill on a series II? And how much oil?:D
  6. 00-Saleen New Member
    Sep 2, 2004
    Message Count:
    590
    I h eard every 30K Miles using 5w-50 Synthetic Oil.
  7. ExtremeSaleen New Member
    Mar 31, 2005
    Message Count:
    236
    I just confirmed with Saleen thru a call with both Sales and Tech support that the older oil in the SC's should be changed around 5,000 miles. That's their recommendation anyway. There seems to be a lot of different views on this issue. KB says 12K for their system, Saleen says 5k for their twin-screw blowers with older oil, 50k with the newer NYE oil. but I have also seen Whipple say 30k if you use synthetic 50w gear oil. :shrug: I don't think though that 100k is the way to go in any case.
Share This Page
