Tach signal help
Discussion in '2005 - 2009 Specific Tech' started by jlisle01, Aug 12, 2008.
  1. jlisle01 New Member
    Dec 29, 2004
    Message Count:
    250
    Hey guys. Can one of you guys who have installed an aftermarket tach tell me where you got the signal input? I REALLY don't want to have to get a sewing needle and a meter and go searching through the :mad:FIFTY THOUSAND:mad: wires coming out of that ECM. Surely there's a tach signal in there somewhere!?
  2. DarkFireGT Playing with my wife's really makes me want one.
    May 23, 2004
    Message Count:
    2,640
    56
    For a nitrous window switch or raptor shift light, you can tap into a coil wire. So one would assume you could use that.
    Here's a shift light installation:
    MustangHowTo Links Page
  3. jlisle01 New Member
    Dec 29, 2004
    Message Count:
    250
    No, I need a tach signal. Basically I need something that changes voltage as the engine rpm changes. In the SN95's you need a tach signal driver which I believe you do splice into a pair of coil wires and it converts that into a tach signal. But nobody seems to make one for a S197 so I'm guessing that that means there is a tach signal already coming out of the ECM. The stock tach has to be driven off of something. Don't tell me that nobody at Stangnet has wired up a Monster tach in their '05 up!
Share This Page
