taking steering column out
Discussion in 'Classic Mustangs' started by joners, Dec 29, 2005.
  1. joners Founding Member
    Jan 10, 2002
    Message Count:
    394
    Winnipeg
    Well I have the car basically stripped ('66 Coupe) and the only thing left is the steering column. How do I take it apart from the steering box? I have to replace the firewall so it must be out soon! It doesnt say in my manual how to do so.
  2. 66stangbluework New Member
    May 5, 2005
    Message Count:
    113
    there will be two studs with nuts on them, i believe they are 1/2 size for ur ratchet. These are found just after the half circle in the dash that the steering column goes through, take these nuts off the 2 studs and remove the column by twisting/ pulling out, and of course removing the steering wheel.
  3. 69Rcode_Mach1 Active Member
    Apr 21, 2004
    Message Count:
    1,478
    36
    Salt Lake City, Utah
    Yep what he said, there may also be some bolts that hold a boot to the firewall that will have to be removed as well. It is very simple though just 3-4 bolts I think I can't remember exactly.
  4. joners Founding Member
    Jan 10, 2002
    Message Count:
    394
    Winnipeg
    So you have to remove the steering wheel to pull out the column from the steering box? I already had the support piece to the dash off.
  5. dennis112 Active Member
    May 15, 2005
    Message Count:
    1,326
    38
    Amish Wonderland of Central PA.
    Yes you have to remove the steering wheel too--remove the large bolt and, with some luck, you can palm hit it from behind on both sides and it will pop off. Otherwise you will need a steering wheel puller (a harmonic balancer puller will also work in a pinch.)
  6. Edbert Founding Member
    Jul 14, 2002
    Message Count:
    3,442
    56
    Austin TX
    The wheel MUST come off first.
    Two bolts hold the column to the dash.
    Four hold the bracket to the firewall on my 67, but you may get her out without removing that (depending on condition).
  7. joesgt281 Founding Member
    Oct 2, 2002
    Message Count:
    165
    Katy, TX
  8. 69Rcode_Mach1 Active Member
    Apr 21, 2004
    Message Count:
    1,478
    36
    I think he just wants to take the whole thing apart as an assembly. If so he just needs to do the two nuts that link it to the steering box, then he needs a pitman arm puller and undo the 3 bolts that hold it to the engine bay and out comes the box if he wants that out too.
  9. joners Founding Member
    Jan 10, 2002
    Message Count:
    394
    Winnipeg
    WOW, I didnt know that the shaft was one piece to the steering box...
  10. Edbert Founding Member
    Jul 14, 2002
    Message Count:
    3,442
    56
    Austin TX
    Maybe in a 68-70 it does...LOL. Getting the steering column out is easy, but that long shaft is nearly a permanent part of the box and the box wont fit through the firewall. getting the box out with the long shaft is...FUN! Plan on taking out the driver's seat, that will be a requirement, it also helps if there's no motor in the car.
    I did this not too long ago, here's some pictures of my column:
  11. joesgt281 Founding Member
    Oct 2, 2002
    Message Count:
    165
    Katy, TX
  12. Edbert Founding Member
    Jul 14, 2002
    Message Count:
    3,442
    56
    Austin TX
    I can only guess that having the engine out made it possible. I had no headers on mine and the seat out (still is too...LOL) and it still took a bit of jockeying.
  13. fastdave New Member
    Apr 20, 2003
    Message Count:
    144
    Chandler,AZ
    Dont forget to unplug the wiring harness for the turn signals and horn....
  14. joners Founding Member
    Jan 10, 2002
    Message Count:
    394
    Winnipeg
    Everything is pulled, EVERYTHING!
    Only thing left in the interior is the steering column. Replacing firewall and floor over the next few weeks.
  15. 66stangbluework New Member
    May 5, 2005
    Message Count:
    113
    I pulled my longshaft :lol: out with the engine in with headers and the seat in what a pain dinged up my freshly painted headers, alot. crapola
Share This Page
