I had to replace the water pump on my '89lx today so....
I also replaced the thermostat and the radiator hoses.
I also went ahead and replaced the timing belt since I have no idea when it was last done.
But now, I have a whine coming from the engine, sounds like from under the timing belt cover.
To get the belt cover off I had to take off the serpentine belt idler pulley.
What's the torque spec on that bolt that holds the pulley to the idler body?
Can you have the timing belt to tight?
The spring for the timing belt idler pulley didn't have enough strength to push the belt tight so I helped it into place then tightned down the nut.
