Tire Pressure warning light flashing
Discussion in '2005 - 2009 Specific Tech' started by mustangford289, Nov 10, 2009.
  1. mustangford289 Founding Member
    Sep 17, 2001
    Message Count:
    970
    28
    Florida
    I had 2 tires put on. The next day I noticed the light flashing then just staying on....Tire pressure is good. The owners manual says it is a malfunction often found after changing tires. Does anyone know what to look for, as far as the sensors or whatever is causing this problem and or, how to fix it?
    2008 GT
  2. 09v6 New Member
    Sep 12, 2009
    Message Count:
    Your TPMS was either damaged or needs to be recalibrated. Take the car back to the tire place and ask them to reset the TPMS monitors inside the tires and if that doesn't work, then you know they messed them up, if they were working properly before the tire change. The TPMS has a sensor located on the inside of each tires, strapped to the rim.
  3. stanmckinney Active Member
    Mar 31, 2005
    Message Count:
    1,180
    38
    If they changed the tires correctly, the sensors should not be damaged.
    If they are, you may have to buy new ones and the bands holding them onto the wheel. The bands are designed so that they are not reusable.
    The sensors should reset in a matter of minutes of driving if they were not damaged.
  4. mustangford289 Founding Member
    Sep 17, 2001
    Message Count:
    970
    28
    Florida
  5. SpartaPerformance StangNet Sponsor
    Nov 5, 2006
    Message Count:
    1,816
    38
    Long Island NY
    Most places don't know that Fords primarily use band sensor that is strapped to the rim, they bead breaker on the tire machine can rip the band off. most likely thats what happened. If there was a hard malfunction the light would constantly flash
  6. Wind-Farmer Member
    Sep 2, 2008
    Message Count:
    271
    Minnesota
    Buy a reset remote control. $40
Share This Page
