Tire Size Question
Discussion in 'Classic Talk' started by greengene67, Jun 11, 2005.
  1. greengene67 New Member
    Jun 1, 2005
    Message Count:
    SoCal
    I am putting a 289 inside a '67 coupe. It was originally a 6cyl. Just curious what size tires to run in the front and in the back. Any inpute is much appreciated!
  2. Cobain03 New Member
    Aug 27, 2003
    Message Count:
    1,023
    Lexington, Ky
    currently i have 195/70/14s but they are all bald right now :) so im waitin till i can save up enough for some new tires. i will prolly go with a 205/70 14 or similar.
    keep in mind that the bigger tire you got, the worse your speedo will be.
  3. 67GTFB Member
    Apr 2, 2005
    Message Count:
    121
    18
    as a point of reference, I have an original F70-14 Firestone Wide Oval tire mounted on a stock rim that I have as a "spare" -- well, it's in the trunk anyway .... I too am looking at getting new tires, so just for kicks I measured the thing ... it measures 7.75 in in section width and 25.5 in overall diameter .... if you use one of the many tire size calculators, this equates out to a 197/74-14 (so much for a "70" profile) .... if one checks out tire retailers, such as Coker, they have a "replacement" tire that has advertised dimensions of 8.3 in section width and 26.5 in overall diameter .... I contacted Coker about their tire dimensions vs the dimensions I measured from an original .... interestingly enough, the good folks at Coker said that although they use original molds, they perform an additional "post-inflation" step on each tire as it comes off of the mold ... and apparently this extra process (not done in days of old) increases the tire dimensions slightly -- go figure .... so, bottom-line is that an old F70-14 is closest to an 7.75-14 in overall dimensions .... there are several web sites that show an F70-14 having the "newer" inflated dimensions (8.3 & 26.5) .... but it's hard to argue with an original (that still holds pressure BTW) .... hope this helps ....
    cheers,
    67GTFB
  4. greengene67 New Member
    Jun 1, 2005
    Message Count:
    SoCal
    Cool, thanks for the info! Awesome car! Sounds like a nice Stang.
Share This Page
