TPMS Programming
jonmar
9
Virginia
Anyone know how I can get my 08 Mustang to go to "program mode" so I can use my TPMS Programming tool? I searched and tried the suggestion of turn key to run position 3 times, etc. It did not work. Help Please!
off the top of my head, it goes something like this.
turn key to run w/o starting engine
tap brake pedal
turn key to run w/o starting engine - leave in RUN position for the training
It has been a few months since I last used mine but I think that is the sequence you need
I bought the ford tool to program it at home and found some directions on a mustangforums post....can't remember which one though. If you still haven't found out by the time I get home from work, I'll try to remember to look it up for you.
ARTTII is correct here is a pdf you can print and keep with your tool. Just click on the link to view it and print file was to large to attach.
http://www.imagetex.com/albums/userpics/10003/TPMS_Sensor_Training.pdf
tap brake pedal
