Tranny Cooler Help!?!?
Discussion in 'Mustang II' started by JonDawg, Feb 26, 2004.
Thread Status:
  1. JonDawg Mstng2 supplied me with my pair
    Aug 4, 2002
    Message Count:
    444
    See those taillights right in front of you?
    Hi all. I got my V8 radiator (finally) and now I need to know what to use to hook up the trans cooler tank to my AOD.
    First, I dont think the cooling lines are pressurized, but it sure leaks like a siv when I use fuel line. So, what do ya'll use? Also, What fittings go into the tank itself? I called Summit, and they said its not the same stuff they have in their catalogue. So what fittings are they, and where do I get em? also what size?
    Im sorry if these are dumb questions, but Im having a brain fart (new job n all)
    Thanx for the help.
    Jon. :banana:
  2. zwhitr Founding Member
    Aug 27, 2001
    Message Count:
    851
    Goldsboro, NC
    Cooler lines are pressurized
    Most of us use the stock steel lines, however I have been enterning the idea of new stainless braided rubber line front to back I have one small patch piece that works fine with hose clamps but looks like a$& :shrug:
  3. cobraii351 Founding Member
    Jan 10, 2000
    Message Count:
    1,102
    36
    Altoona, PA
    Always, always, always, use line/hose that is rated for or labeled for tranmission cooler use. There is a difference.
    Tim
  4. chaka Founding Member
    Mar 1, 2002
    Message Count:
    1,371
    Boston, MA
    They sure as hell are pressurized.
    I have used steel brake lines. You can buy the line at Autozone. It has two fittings. You will have to match it up. Want to say 5/16" line but am unsure.
    Then to go to rubber I use EFI rubber fuel line and add a flare at the end of the hard line for a better seal. Has worked for me.
  5. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    NE Ohio
    Check your mail.
  6. JonDawg Mstng2 supplied me with my pair
    Aug 4, 2002
    Message Count:
    444
    Thanx all. Noone around here has a clue, so I had to ask the pros. Ill just take the radiator in to get the size of the fittings.
    Now with the rubber lines, how do they seal to the steel lines? regular hose clamps? Ive got about 5" of steel line from the tranny, so if I can just flare it and put rubber lines on from there, so much the better.
  7. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    NE Ohio
    Hoosierbigdaddy@juno.com
    You don't read replies to questions you post to The List ?
  8. chaka Founding Member
    Mar 1, 2002
    Message Count:
    1,371
    Boston, MA
    You can either use a compression fitting between the hard lines,
    But as long as you use EFI fuel line with hose clamps and flare the hard line a bit it will hold.
  9. COBRA 7 Founding Member
    May 19, 2000
    Message Count:
    445
    18
    Bangor, Maine
    When putting your steel line to the flexable hose...( Fuel injection line or hydraulic hose )... use a double flaring tool on the steel line but don't do step two of the double flair.
    This will leave like a bubble on the end of the line.
    Kind of like this. <>=====
  10. danimaltheanima New Member
    Dec 4, 2003
    Message Count:
    181
    trans cooler lines
    Call up Mustangs Unlimited. They sell exact fit stock cooler lines for the MII.
  11. JonDawg Mstng2 supplied me with my pair
    Aug 4, 2002
    Message Count:
    444
    What are you talking about Wart? I havent gotten a thing except the reply notes. I even checked my PMs here, and I got nothin?
    If you sent something, Please send it again. Im sorry, but I didnt recieve it.
    Nevermind, I found it. That list is quite a bit behind "real-time" since I had it condenced into multiple posts. :( So I just got it when I logged on.
    I appreciate it.
    Thanx Mark, and thanx everyone.
  12. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    NE Ohio
    Don't blame The List, Jon, you posted a question and you didn't bother checking back.
    Jon, you recieved 3 replies within 18 hours after posting your question. And the information was much better than anything you received here.
  13. JonDawg Mstng2 supplied me with my pair
    Aug 4, 2002
    Message Count:
    444
    Mark, Dont be a Dick!!!
    Some of us have more things to do than sit in our basements and type on car lists all day. You know, theyre called "lives"
    Now for those who are jealous of us with these "lives" I suggest you go find one of your own. Then maybe you wont be so ****y when others dont kiss your ass within 10 minutes of your reply.
    Now if ya wanna keep it up, just GET OFF MY THREAD!!!!!!!!!
  14. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    NE Ohio
    Don't put your faults on me, Kid.
    You don't understand why someone would be irked when they have taken the time from their lives to answer a question only to find the person asking the question was so frigging lazy as to not check back, then makes excuses.?
    Or is it that your so egotistical as to think yours is the only time that has value?
    Or is there another purpose to this?
    Come on, Jon, you can tell us.
  15. JonDawg Mstng2 supplied me with my pair
    Aug 4, 2002
    Message Count:
    444
    Oh, God forbid someone leave you waiting mark. and for 18 hours too. Oh, the nerve!!! (and Im egotistical :rolleyes: )
    Tell ya what, get up from behind your computer, walk out of your room, and take a look outside. Theres a bright orange ball in the sky, its called the sun. Go out and enjoy the heat.
    After your playtime, we can talk more. Until then, Like I say, I have more than this piddly lil laptop to deal with.
    So until you get over being a genital wart, I bid you adue!
  16. JonDawg Mstng2 supplied me with my pair
    Aug 4, 2002
    Message Count:
    444
    Ok, let me rephrase that. I mean noone in this area of the country. Not on this site. Well, Wart dont have a clue, but. . . . .
    So, sorry for any confusion.
  17. 77sleeper GO BUCS!
    Oct 11, 1999
    Message Count:
    7,495
    Napalm, AZ
Thread Status:
Share This Page
