Well im currently trying to tackle some other issues on the car but i figured while at home i could work on some tune issues...
Looking at data logs from a wot run im seeing low voltage from my HEGO's
IIRC this means im running lean..
My Wideband also reads lean...
HOWEVER i failed inspection for having my HC's 8 times the limit...
This leads me to believe im running rich... Very Very Rich... so rich that im shooting unburnt fuel in to my exhaust and im reading lean.
SO in order to start to tune this thing i need guidance.... First im told to get my Maf transfer for my 24lb pro m maf.
Done.
Ive also uploaded the 24lb injector template.
And pulse width for long tubes.
Now i was told to "remap the LAMSE table for OL startup and OL stabilized"
How do i go about doing that? I want to pull 5%-10% fuel to test my theory stated above. I also need to know how to do that...
Thanks,
Adam
306, Keith Black Flat Top Pistons, TFS/KPI HiPorts, Wolverine 1190 Cam, TFS Track Heat, 1 3/4'' Accufab Headers, 70MM Accufab TB, 24lb Injectors, 24lb Pro M maf, Innovate LC1, Moates QH, BE, EECA
Done.
Thanks,
Adam
Best bet to have it running decent right off the bat.
