tuning a 351 conversion-t4mo questions
Discussion in '94-95 5.0 Tuning' started by poboys 94, Apr 17, 2007.
  1. poboys 94 New Member
    Dec 6, 2006
    Message Count:
    155
    St. Louis Mo.
    l have a question as to how one would tune, flash, a t4mo to run a 351w. Possibly a 357 mild daily driver,afr185s, etc, or would a pcm out of a donor truck bolt on and adapt to mild mods?Looking for about 375 hp at the flywheel.:shrug:
  2. Don 95Vert Founding Member
    Oct 1, 1999
    Message Count:
    1,132
    36
    Delaware, OH
    Not a lot different than a similar modded 302. You have to make a couple of changes in the tune for the increased engine displacement, and the normal tuning mods, and you'll be fine. We've done a ton of chips for 351 swap cars - including our own 357 turbo shop car.
    You cannot flash T4M0 processors, chips/TwEECers/EEC Tuners are the only route.
    Make sure you have adequate MAF and injectors for that HP - minimum 30# injecotrs, though I'd go with 42's and probably a 90mm Lightning MAF - you would need a tune for that MAF injector combo.
    If you have any other questions email me at don@lasotaracing.com
    Good luck!
    Don
  3. poboys 94 New Member
    Dec 6, 2006
    Message Count:
    155
    St. Louis Mo.
    Thanks for the info, I assume the stock pcm will get me around for a while till I can get it tuned?
  4. Don 95Vert Founding Member
    Oct 1, 1999
    Message Count:
    1,132
    36
    Delaware, OH
    Yes, but using the stock MAF and injectors, I would not take it over 1/2 throttle or the MAF will peg and you'll run out of injecotr. Any MAF or injector swap will require a tune.
    Don
  5. poboys 94 New Member
    Dec 6, 2006
    Message Count:
    155
    St. Louis Mo.
    So installing bigger injectors, and using my Pro-m 75mm MAF re-calibrated to the bigger injectors, she'll be drivable?
  6. Don 95Vert Founding Member
    Oct 1, 1999
    Message Count:
    1,132
    36
    Delaware, OH
    Should be as long as the MAF calibration is OK - sometimes they are not. I still would not get on it, because the load calculations will be off with the larger dislacement - so timing at WOT will be off.
Share This Page
