tweecer issues per version
Discussion in '94-95 5.0 Tuning' started by blksn955.o, Jun 2, 2007.
  1. blksn955.o Founding Member
    Mar 15, 2002
    Message Count:
    3,266
    66
    st.louis mo 314
    Starting a list of known bugs with the tweecer software. I would like to keep this broken down to specific versions so please if you have any comments leave the version for reference.
    I run 1.3A9
    The bugs I have run into are...
    The spikes in the datalogs. These spikes are for example for no reason a 14v or max value will be in the middle of the data in a log.
    When making any change to any tab in cal-edit the "update only" box gets checked. This needs to be un-checked before saving or writing to the eec.
    feel free to add any more and issues with other versions.
  2. m0l0 New Member
    Nov 21, 2005
    Message Count:
    178
    +1 To all the last ones.
    Plus the horrible need to Write the tweecer when you change the payloads, if you dont do this you will see out of the reallity numbers like 50 constant spark, 9000 rpms
    I think also that the rounding of the numbers on all the values is also a pain
  3. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    I use 1.20B3
    You can't include both act and ect in a payload at the same time. If you do,
    the result is both record the correct temp at the start of the dlog but it
    does not change from that point on.
    You can't see ect at all.
    You can see act however.
    When working with the maf transfer curve, you must hand load all cell values
    and check after saving the file because some of the time, the values will save
    to some hokey value.
    I kinda think this behavior is present in some of the later versions as well
    but can't be certain of this suspicion.
    There is no hokey data values or data drop outs present in data logs of this software version I might add.
    Grady
Share This Page
