Updating KAMRF
Discussion in '94-95 5.0 Tuning' started by Guero, Apr 16, 2007.
  1. Guero Active Member
    Oct 12, 2005
    Message Count:
    2,195
    46
    How do you get them to show on the datalogs??? I've tried disconnecting the battery over night, pressing the brakes for 30 seconds, and with the battery disconnected I touched the wires. But they just show up on my logs as 1. Aren't they suppose to move like the Lambse???
  2. tjh566 New Member
    May 22, 2004
    Message Count:
    615
    Northern Va
    they are suppose to be 1 as far as I understood, 1 means its dead on, more or less than one means somethings a little off in the AFR/tuning.
  3. WhiteDevil New Member
    Feb 5, 2003
    Message Count:
    2,720
    San Diego
    The problem is you keep resetting it. They will stay at one for a couple drive cycles until the have "learned" enough information for the computer to start making long term changes which is what KAMRF is.
  4. Guero Active Member
    Oct 12, 2005
    Message Count:
    2,195
    46
    Oh ok! Ill keep running the Calcon on, and see if they change
  5. m0l0 New Member
    Nov 21, 2005
    Message Count:
    178
    Karmfs will start to move arround once some parameters meet the criteria of the EEC for examle on the scalars there are two called "ACT Maximum & Minimum for adaptive control" and i think another ones , so once this parameters are meet the adaptive control (Karmfs) will start to move :nice:
    Definitely there more on this matter as the function table that controls the adaptive function.
    I hope some others with more experience will chime in and expand this matter :nice:
    Also in case you missed! don't forget to activate on the payloads the karmfs logging!
Share This Page
