Water Pump
Discussion in 'Fox 5.0 Mustang' started by roush 97, Mar 7, 2004.
  1. roush 97 New Member
    Aug 28, 2003
    Message Count:
    86
    Well, I investigated my leak and it wasn't oil after all but coolant. I believe it's coming out of the water pump. Obviously it needs replaced, is there anything else in there I ought to do whille I have it off and out of the way? I haven't had a very good water pump year. I have two farm trucks '89 and '90 with a 7.3L diesels in them. I replaced the pump on one that started leaking out of the hole in the bottom and not 1 day later the other one started. Also had to change one on a grain truck about 2 weeks before that and about a month later this. Looks much easier to get at on the mustang though. Just wanted to make sure there isn't anything else I need to so while I got it out. Got 150 k on it and I fairly new to working on 5.0's.
  2. gt90stang New Member
    Dec 7, 2002
    Message Count:
    569
    Yeah,
    Put in a new T-stat 180 Mr Gasket is good. Also replace the bypass and heater tube hoses. Might also be a good time to put on some under drive pulleys. I went with a Edelbrock water pump and it is really built good with roller bearings and pumps more water than the stock pump.
    Good Luck, Don
  3. roush 97 New Member
    Aug 28, 2003
    Message Count:
    86
    Thanks for the info. I'll do that.
  4. bmo37 Founding Member
    Jun 28, 2001
    Message Count:
    2,368
    i bought the summit 30% more flow polished pump but haven't put it one yet, looks pretty cool though for 110 beans
Share This Page
