Waterpump
Discussion in '2.3L (N/A & Turbo)' started by Dr_EluSivE, Feb 27, 2004.
  1. Dr_EluSivE Founding Member
    Apr 24, 2002
    Message Count:
    2,387
    56
    Central Illinois
    my car has had a constant wet spot underneath it for a few days now so i checked the anitfreeze and sure enough, the overflow is empty. The car was hot so at the time i did not check the rad. Well after a trip to the parts store to get antifreeze i opened the radiator and was not at all happy with what i found. It looks like there is Mud, and lots of it in my cooling system. So assuming noone put actual Mud in my radiator i am guessing that oil is getting into the cooling system some how. :notnice: So i added some coolant and figured Oh well. But i noticed antifreeze dripping off of my sway bar and traced the wet spot back the the vicinity of the water pump. SO... my question is.. How hard are water pumps to change? It seems i may have a bad head gasket (or cracked head) anyway so i am not too eager to do much work to the N/A motor but i DO need something to drive and the turbo is not ready. Is the water pump easy and worth changing in this case? The water is NOT getting into the oil yet, and i have no idea how long its been like that but it may have been mixing for a long time for all i know. DO i have to remove the timing belt to change the pump? Lets hear your opinions..
    Dr.
  2. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    It only takes about 30 minutes. Maybe an hour if you take your time. No need to remove the timing belt, just the acc belt.
    It's just 3 bolts that hold it to the block and the pulley bolts.
    Stinger
  3. MustangPatty Founding Member
    Jun 5, 2002
    Message Count:
    293
    Sallisaw OK
    Yea, it aint that hard at all, I set aside a day a few weeks ago when I did this on my SVO, When I was done I felt riped, I was looking foward to a full days car work...LOL
  4. 140cilx Founding Member
    Sep 7, 2001
    Message Count:
    2,385
    GA
    it takes me about 2 weeks to get it scheduled, then about an hour to actually do it.
  5. Dr_EluSivE Founding Member
    Apr 24, 2002
    Message Count:
    2,387
    56
    Central Illinois
    Well so the water pump doesnt sound like that big of a deal thats good. Im sure i break off a bolt and it will take me 3 hours but seems like something i could do in a weekend. Sounds eaiser to change than the MG one and the MG water pump is really easy! What is your take on the oily mud in my radiator though? Should i baby this thing now? there is no water in the oil, but the water in the radiator even smells like oil so i am a little concerned about that. not sure how much longer the N/A is gonna last.. :( (Secretly grins hoping turbo swap comes soon :D )
    Dr.
  6. Anlushac11 Founding Member
    Feb 17, 2001
    Message Count:
    2,270
    Indianapolis, Indiana
    Anyone tried the aluminum hipo water pump? IIRC Esslinger sells one and I have seen it on Ebay also.
  7. Stinger Founding Member
    Jul 7, 2001
    Message Count:
    7,726
    Wilson, KS
    Ebay and Esslinger are different ones. The ebay unit is also sold by Bob Lee.
Share This Page
