Weird driveability problem... Hmmm
Discussion in 'Fox 5.0 Mustang Tech' started by UnderPressureGT, Oct 3, 2004.
  1. UnderPressureGT Banned
    Jan 1, 2003
    Message Count:
    2,315
    TR- Jersey Shore
    This started tghe day i retarded my timing down to 8 for my blower 2 days ago.. I would drive through the gear with some to no boost and the motor would sound like its revin up, but wont be going nowhere.. as if it was bogging and making popping sounds under the hood .. then after a certain RPM, say 4000, it will cut right back on and take off like nothing happened.... Today driving around for a while, i noticed the problem went away after a half hour without a trace of what happened.. I could now rip through all the gears with no problem.. Now i would bet the problem is going to come back tomorrow.. what gives??
    i am going to put the timing back to 10 to see if anything changes, but if it was a timing issue, wouldnt the problem be always, not by how long im driving????
  2. UnderPressureGT Banned
    Jan 1, 2003
    Message Count:
    2,315
    TR- Jersey Shore
    ttt anyone knows?
    Sponsored Ad
  3. jadedinpa Founding Member
    Aug 3, 2002
    Message Count:
    1,096
    lancaster, pa
    i'd say it's the pick up coil in the distributor.
  4. UnderPressureGT Banned
    Jan 1, 2003
    Message Count:
    2,315
    TR- Jersey Shore
    is that a hard thing to replace and how much is one??? and how do i know for sure if thats it??
    driving around for a while will fix the problem... but until then, it popps under load under the hood and doesnt want to move anywhere until a higher rpm sayy 4000, then it will cut on like nothing even happened and will fly through the rest of the gear...w eird
  5. jadedinpa Founding Member
    Aug 3, 2002
    Message Count:
    1,096
    lancaster, pa
    maybe not then- mine was the exact opposite. it would run fine for a while but then get progressively worse. it wouldn't even start if you shut it off when it was hot. had to let it cool down to restart it.
Share This Page
