what headers
Discussion in 'Classic Mustangs' started by smokeshow68, Jul 5, 2004.
  1. smokeshow68 New Member
    Jul 3, 2004
    Message Count:
    im doing a auto to 5 speed swap, im going to send my pedals to mustang steve i heard try y's have to be modified but i would rather get new one but i dont know what header will have the most clearance for the clutch cable
    can any one help
    thanks
  2. 6Stang7 New Member
    Jun 1, 2003
    Message Count:
    1,564
    You know, I am not sure why the cable touching the headers ina problem. I have tri-y's as well, and the cable I am using is touching the headers, and has been for the past 600+ miles and I haven't had a problem. The cable is inside a metal sleave, and the cable it self is metal. I don't see what can break.
  3. TT670 Founding Member
    Jul 11, 2001
    Message Count:
    333
    Im using Mustang Steves cable kit with MAC longtubes, its tight in the header area but so far there are no heat issues with the cable.
  4. skywalker New Member
    Dec 23, 2003
    Message Count:
    742
    smokeshow: any headers will work as long as the cable is wrapped generously in heat wrap where it touches the headers.
  5. STSFCTN67 New Member
    Feb 6, 2003
    Message Count:
    451
    Give it more time and it will break for sure. The heating and cooling of the cable breaks it down and it will snap. You will know when the cable is heated up too much when one day you go out to your car and the clutch pedal is hard as a rock and you will need to pump it to break the melted plastic form the metal sleave. You do not want to use heat wrap and you want to make sure air passes between the header and the cable. You want to be sure the cable is not touching. If I could do it all over again, I would go with short tube headers. Continue to ask around or ask Mustang Steve directly - he would know for sure.
  6. skywalker New Member
    Dec 23, 2003
    Message Count:
    742
    I disagree.
    I Wrapped miine is this exhaust repair gauze that you can buy at any auto parts store, then in heat tape, then i put the foil heat wrapper that came with it.
    After several months like that I have zero damage to the cable and the headers run hotter than hades.
  7. 6Stang7 New Member
    Jun 1, 2003
    Message Count:
    1,564
    I don't see what plasitc can metal onto the cable. It is a metal cable in a metal tube. THere are plastic end, but I have touched them after a nice hour of hard driving and they were hot, but not hot enough to where I couldn't hold my hand on it.
Share This Page
