Wheel Differential? help
Discussion in '94-04 V6 Mustang' started by bigjock, Sep 18, 2009.
  1. bigjock New Member
    Apr 29, 2009
    Message Count:
    22
    Hi i have a 2000 v6 automatic mustang and it needs to replace the wheel differential. Can i put it a GT one or do i need the whole rear Axle? I know that the gt has a tlock and its a 8.8 axle. i need help. Also can you tell me the advantages and disadvantages if there any. and what year from a gt can i take the gears or axle.
  2. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    what would be this wheel differential you are referring to? if you are talking about the centre section of the rear axle assembly, then no you cant use a GT one unless you get the whole housing assembly with axles, gears, bearings etc.
  3. bigjock New Member
    Apr 29, 2009
    Message Count:
    22
    yes the centre section where the gears are. They sell me that section for 49.99 and for the whole axle is 84.99. It does not matter if its a gt or v6, the price is the same, so would it be better if i install the gt whole 8.8 axle? is the same price and the gt has a tlock, instead of buying the tlock for the v6, whch it would save me money.
    and what mustang years can i take the rear end gearing or the whole axle?
  4. bdcardinal tree hugger
    Jun 10, 2003
    Message Count:
    3,670
    56
    the GT centre section will NOT fit in a V6 housing. you need the housing from a 99-04 GT to be a complete bolt in. if your vehicle has ABS, you need to make sure that the GT axles have the tone rings.
  5. bigjock New Member
    Apr 29, 2009
    Message Count:
    22
    and what years can i take the 8.8 axle of a GT. my car is a 2000 v6 automatic. and does it matter if the GT axle is auto and manual?
Share This Page
